Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 02-05-2007, 08:30 PM
NateS's Avatar
NateS NateS is offline
Send a message via AIM to NateS
Best way to clean block for a new HG
What is the best way to clean off the block for a new head gasket installation? I have heard of of few different ways but, I am curious as to what everyone else does.
95 GSX 5 speed
2.3L stroker bored .020 over
Built head
Bullseye/Borg Warner T04B 57 Trim Turbo
RNR 3" turboback w/ o2 eliminator
255 lph Extreme Motorsports fuel pump
Extreme Motorsports mbc
SAFC
Greddy Type S BOV
FMIC (core 28x10.5x3.5)
FIC 650cc fuel injectors
RK Sport Fuel Pressure Regulator
My Car Domain
Old 02-05-2007, 08:33 PM
defiancy's Avatar
defiancy defiancy is offline
Stay classy San Diego
Re: Best way to clean block for a new HG
I would use alcohol. Especially if it's still in the car. You could probably use some degreaser but I don't know if I would want that going into the actual block itself. So I would just use alcohol and wipe the top of it off, make sure it's nice and flat so you get a good seal when you put the gasket and head back on.
1991 GSX 2.3 Stroker
Old 02-05-2007, 08:35 PM
xavier3jr's Avatar
xavier3jr xavier3jr is offline
Send a message via AIM to xavier3jr Send a message via MSN to xavier3jr
i took a die grinder(or dremmal if you have one) and got like a fiberglass rough pad i dont remeber what it was called and grinded all the stuff off letf kind of a ruff surface but not to ruff of a surface. worked good for me.
96 GS - 5 Speed-Sold
1998 Ford F-150 XLT 4X4
Old 02-05-2007, 08:54 PM
NateS's Avatar
I've been using a gasket scrapper(pretty much just a razor blade) and degreaser. It still leaves behind a very small residue looking film on the block though. A friend of mine suggested using fine grit sandpaper but, it didn't sound like a good idea to me. When you say alcohol what alcohol do u mean, like rubbing alcohol or what?
95 GSX 5 speed
Built head
SAFC
Greddy Type S BOV
My Car Domain
Old 02-05-2007, 10:02 PM
xavier3jr's Avatar
sand paper would work to but you dont want a perfectly smooth surface leave it a little bit ruff
Old 02-05-2007, 10:09 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
I always use a wire-wheel attachment on a grinder (as does my auto instructor at school), works for me everytime.
Get one like one of the top two in the pic, that's what I've got.
95 Talon TSI AWD
97 Eclipse GST
Old 02-05-2007, 11:37 PM
defiancy's Avatar
Yes rubbing alcohol.
The reason rubbing alcohol is great for cleaning is because, 1 it cleans, 2 it evaporates shortly after being applied to a surface, so you don't have to worry about leaving excess on the block.
I would agree with what is said above, a light grit sand paper and alcohol may be a good combo. You just don't want to get an sandpaper that is going to put groves or flaws into the top of the block.
When I worked on helicopters in the military we used alcohol to clean pretty much everything. It works wonders.
