Old 02-05-2007, 12:19 PM
peculiarmike peculiarmike is offline
01 Fuel Sender
My fuel gauge on my 01 2500HD either works fine or drops to empty and the low fuel indicator comes on. Local dealership says the sender is bad and they would gladly install a new one for a $450.00. Appears this is a common defect. We ain't talking rocket science here.
How do you get to this thing? Does the tank have to be dropped?
Old 02-05-2007, 12:41 PM
masapell's Avatar
masapell masapell is offline
Re: 01 Fuel Sender
Welcome to the forum!! There are several schools of thought on this one. Here's the link to the thread.
http://www.automotiveforums.com/vbul...t=sending+unit
Mine has started doing this, so I am not looking forward to this costly repair. I do have a friend who is a service manager of a local dealership, so I can get it done cheaper, but it will still be a chunk of change. Hope the above thread helps. It sure would be nice if there was an access panel!!
2014 Ram 1500 Crew Cab
Old 02-05-2007, 12:56 PM
Re: 01 Fuel Sender
Looks like the consensus is remove the bed. Now, if the weather would just warm up..................
Course, if it does, I'll probably just go fishing.
Thanks!
Mike
Old 02-05-2007, 03:08 PM
silverado122775's Avatar
silverado122775 silverado122775 is offline
Re: 01 Fuel Sender
The sending unit is the Fuel pump. $450 is the cost of the fuel pump with the built in Sensor for the fuel gauge. I will bet the stealership will charge another $450 to replace the pump. If you can do it yourself, it would be wise. Just buy a couple of six pack your friends to help you take the bed off. Just rember to disconnect all your wiring to the taillights and hose the gas inlet hole.
2000 Silverado Z71, 5.3L, K&N GenII Air Intake, Y-pipe Exhaust (no muffler), Bosch Platnium +4 plugs, 242k miles and still running.
Old 02-05-2007, 04:37 PM
alan &marge pepper alan &marge pepper is offline
Re: 01 Fuel Sender
just two straps holding it up in place.
i would say drop it. it is the best way.
you have to dist connect your lines and filler hose.
or cut a neat hole in the box over the sending unit as i did
once only on three sides and bent it up.
after i bent it back down and tacked it. a bed linner well cover it up.
three oppsion take your pick
Old 02-05-2007, 05:20 PM
rjeffery rjeffery is offline
Re: 01 Fuel Sender
I bought one from Autozone for around $280 and some change (dealer wanted around $7-800 for parts and labor). I did the install myself by dropping the tank. Just make sure the tank is empty if you drop it. I didn't pull the bed because I don't have a hoist, and didn't want to mess with lining it back up. If you're doing it yourself, get a Haynes manual, the entire procedure is explained there.
korndogg's Avatar
korndogg korndogg is offline
Send a message via AIM to korndogg Send a message via MSN to korndogg Send a message via Yahoo to korndogg
Re: 01 Fuel Sender
$450 for the pump?? Thats dealer cost. Dont pay the dealer.
www.gmpartsdirect.com I got my pump/sender for half dealer cost.
It was $200 something
1968 Camaro 327
1999 Silverado 1500 Z71 LT
{o,o}
|)__)
O RLY?
http://www.cardomain.com/id/korndogg002
Old 02-05-2007, 09:42 PM
Sschev Sschev is offline
Re: 01 Fuel Sender
I have an 01 2500 Duramax and the fuel sending unit went out in it. My regular mechanic said take it back to the Chev. dealership and ask them to fix it for free because this is a GM defective part which fails in most GM trucks of this era. I did and they did, they only charged me $25 for some kind of shop fee. As info, they asked me to bring it in when I thought it would be low on fuel and they dropped the tank out from below, never removed the bed. I would pressure the dealership to make the repairs even if you well out of warranty, I was thousands of miles and many months out of warranty.
Old 03-31-2007, 01:28 PM
listenloud listenloud is offline
Re: 01 Fuel Sender
I found the fuel pump/sender unit on ebay for $110. Look up global-automotive. $110 is the buy in now price. It's an aftermarket unit. It looks the same as the Delco unit. Delco retails for about $450. I have a contact at a GM dealer. The best he could get it for was $275 plus shipping. Autozone and Pep Boys have an aftermarket unit for $279-$289.
Old 03-31-2007, 03:09 PM
korndogg's Avatar
Re: 01 Fuel Sender
coulda got a delco unit for $230 from the link I posted. I heard the aftermarket ones dont last long.
1968 Camaro 327
{o,o}
|)__)
O RLY?
Old 03-31-2007, 03:32 PM
Re: 01 Fuel Sender
gmpartsdirect says the parts are no longer available or the number has changed. It also lists the parts as two seperate parts, the sensor and the pump assy.
2008 Honda Civic EXL - Daily Driver
2000 Silverado 1500 LT - Boat and Haul
2005 Honda Pilot EXL - Wife and Kids
1997 Ford Mustang Cobra Convt. - W/E
