Go Back   Automotive Forums Car Chat > Chevrolet > Impala | Impala SS
Old 02-05-2007, 06:08 AM
sassygramma sassygramma is offline
2001 impala blower motor problem
hey ya'll
i am inquiring about a new recent problem where the blower motor on my oh so wonderful piece of crap '01 impala which now has 65000 miles , is kicking on even when car is not running and no key in ignition .
bout week ago noticed it first time when as soon as i put key in igniton it came on before car was even started , and the switch was turned off . this went on for about 10 minutes before it finally shut itself off , and i had then lost temp control 1 , but still had 2 , 3 , 4 , 5 .
now yestrday it also seem to change temp speeds without touching the control switch to where eventually it seemed to be stuck on temp speed 5 , and stays on when switch is agin shut off and car turned off .
i now have to pull the HVAC blo fuse , becasue it seems to be draining battery .
this forum has helped me to determine some of my last problems with this car and am hoping it will help again . i can not afford a new car right now so that means sticking more money into this one . but if you all can help , then i save some by not having to go to dealer again , they charge $125 just to pull into their garage . i am still basically right on schedule , for having problems at bout every 11,000 miles .
Old 02-05-2007, 08:02 AM
SpinnerCee's Avatar
SpinnerCee SpinnerCee is offline
Re: 2001 impala blower motor problem
In addition to the HVAC [1-5] fan control dash switch, there's a relay that applies full power for the higher fan speeds -- the relay may be stuck closed such that the variable control can no longer turn the blower off.
The blower motor speed control resistor pack may also be shorted out -- The blower motor, resistor module, and relay are all located under and behind the glovebox -- to get to them, you need to drop the blower motor -- it's really easy, 3 screws -- you can probably replace the module and relay yourself. Since you can't tell if they're bad by just looking at them (unless they look like they've been under water) -- you may just have to buy the parts and save the labor for yourself.
The problem may also be in the fan speed switch itself -- some WD-40 to the contacts under the speed control knob has fixed this for some.
.:: DigitalMIX by djSpinnerCee ::.
Old 02-05-2007, 01:04 PM
tyvm SpinnerCee for the info . at least i now have something to go on . this forum is the greatest help to me , considering i really only know how to put gas in , check oil and drive the dang thing ; and it sucks going in to mechanics casue being female they really do treat me like crap sometime .
TY TY
Old 02-06-2007, 09:17 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
If you have any other electrical gremlins, like the information center dimming/going out, interior light issues, etc... you may need an ignition switch/harness assembly. This switch is a known issue, the contacts start arching and will cause your symptoms.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 02-06-2007, 06:35 PM
NO other known , electrical or otherwise, issues related to this problem . one thing tho ...even with the HVAC blo fuse pulled , if control speed switch is turned on the blower still runs at speeds 2 - 4 ?? how the heck can this thing still be blowing and running with no fuse ?? but as long as switch is off and fuse pulled , it stays off ...
Old 02-10-2007, 04:01 PM
hey.... just replaced the resistor ($30) and so far everything seems to be working normal again ...if this impala can even be considered normal
tyvm e1 for help
Old 02-13-2007, 10:48 AM
SpinnerCee's Avatar
See, it was easy right.
I'm wondering if anyone has a price for the blower motor itself?
Old 02-13-2007, 09:15 PM
spinnercee .... price we got for the blower motor itself for the "01 impala was bout $90 at autozone , only thing is most parts for this car have to be ordered special , never have anything in stock around here , or have to get right from dealer and more than likely price will be much higher
Old 12-05-2007, 08:32 AM
SpinnerCee's Avatar
An Update -- I had the water leak on the passenger side that first killed the blower resistor (so the fan/blower would only work on the highest setting), then eventually drowned and shorted the blower motor itself:
At the dealer, for the 2001 Chevrolet Impala [Dec2007]:
Blower Motor Assy. [part #52487083] $177.72
Resistor [part #89019101] $49.50
The part #'s are also the same for the 2001 Lumina and Monte Carlo.
Old 12-05-2007, 02:22 PM
57chevyragtop 57chevyragtop is offline
Send a message via MSN to 57chevyragtop
Great post y'all, good info all around thanks....
