Old 02-04-2007, 11:22 PM
luvmyhonda luvmyhonda is offline
cant stop
i think i need to have my brakes worked on, nah i know i need to have them worked on. what will it take to get them back to OEM specs short of takin it to dealership for them to butt rape me? if i recall correct when the 00 V6 accord was new (boutght mine used) didnt it take little or no pressure to stop the car? i feel i have to press the brake a lil too hard to get it to stop like it should. any advice on what to change or what to work on?
Old 02-05-2007, 05:40 AM
jeffcoslacker's Avatar
jeffcoslacker jeffcoslacker is offline
Lactose the Intolerant
Re: cant stop
If it has drum brakes in the rear, the most common cause is misadjustment of the rear linings, which makes for too much brake pedal travel and decreased brake feel....when they use drum rear with an auto tranny the problem is compounded, because the non-servo type drum brakes used on newer cars only adjust up reliably when the parking brake is used...which nobody does with an auto tranny, generally.
When you pull the e-brake lever, does it feel like it's actually doing anything, or can you top it out without really straining yourself? This is usually a pretty good indication that the rear are way out of adustment and not doing anything back there...
Here's what I do first if you suspect this. Find a gentle slope in a parking lot or your driveway, whatever. Allow the car to begin rolling, then jack the brake lever hard. The rear wheels should lock and skid. If not, you are not adjusted worth a damn...now hold the detent button on the lever in, and do this repeatedly, pumping the e-brake lever over and over, you need to pull it as far and as hard as you can each time. If the adjuster hardware is not seized up and useless, after several applications (could be anywhere from a dozen to several dozen times) you'll feel the lever's travel decreasing and the rear brakes getting stronger a bit each time...keep doing this until you feel no further improvement. Then take a drive and see how the brakes feel to you. There should be a definite improvement, shorter pedal travel and a lot stronger braking action.
If you detect no problem with adjustment, and don't feel any of this will help, then the car needs to be checked for glazed linings, seized hardware, booster problem, etc...
Worn out and contaminated brake fluid will give you reduced pedal feel and lazy brakes also, but usually only in extreme cases..
Old 02-05-2007, 10:37 AM
Re: cant stop
thanks alot, it is rear disc. i will try it and tell you how it goes! im glad you told me abou this, hopefuly it wont lead to costly repairs.
Old 02-05-2007, 12:37 PM
00accord44's Avatar
00accord44 00accord44 is offline
High on Potenuse
Send a message via AIM to 00accord44 Send a message via MSN to 00accord44 Send a message via Yahoo to 00accord44
Re: cant stop
trying what? the e-brake test? If I understand Jeff right you don't need to do that since you have discs in back and the mechanics are totally different. Although I suppose it couldn't hurt to find out how well your e-brake is working, but don't base your diagnosis on a test meant to find a different problem.
But in any event, if you've done the test, what happened? Any new developments?
ECNATSISER AL AVIV
Old 02-05-2007, 08:15 PM
Re: cant stop
Yeah with rear disc setup this is largely useless.
does the Accord have the ratcheting screw-type piston for the e-brake of does it use a parking brake drum inside the rotor?
Sorry, I don't know. Can't remember ever working on a 4Wdisc Accord's rears...sure I have, just don't remember.
Would you describe your problem as a soft pedal (lotta travel and lack of firmness), hard pedal (have to stand hard on the pedal to get a reaction) or no pedal issues, just lazy brakes?
Old 02-06-2007, 03:17 PM
Re: cant stop
soft pedal and i dont know if its screw or not but i know its a plain disc in the rear, no inner drum.
Old 02-06-2007, 07:21 PM
Re: cant stop
Can you hit the floor with the pedal if you push as hard as you can?
Try it, and tell me what it does. do it with the motor running. Then pump the pedal full stroke about ten times quickly, and hold it firmly for one minute...if you have a yardstick or something handy, put it down to the floor alongside the pedal to guage how far down it is while you hold...see if you get any drop after one minute, tell me what you find...
Old 02-15-2007, 11:15 PM
Re: cant stop
sorry i havent been her ein a while. the handbrake thing didnt work, so i gess theres no inner drum on the rear brakes. i will try the pedal pumping to see what happens and i will let you all know. thank everybody for your help.
Old 02-19-2007, 03:54 AM
jamescanoot jamescanoot is offline
Re: cant stop
The V6 accords have disc rears and they use a screw type, not a girling. If hard to stop meaning, the pedal is really hard, your brake booster might be bad, or some one did a bad brake job and didn't open up the bleeder screw when pushing back the piston into its housing and got dirt into the master cylinder or your ABS pump.
But!! if i's a spongy pedal(soft) then you have air in your system.
Old 02-26-2007, 12:16 AM
Re: cant stop
its firm and just wont stop. i had to slam on brakes to keep from hittin a deer and i know i stomped the hell out of em. and it felt firm but kept oooon rollin.
Old 02-26-2007, 09:45 AM
accordsforall's Avatar
accordsforall accordsforall is offline
Re: cant stop
Hello everybody,
Im quite new here.. but I also have the same problem on a 4cycl 00 4dr Accord SE with 106k. Somehow.. the brakes just dont get me to a stop at a decent distance.
I compare my brakes.. to a hand going into a fist. When the fist is closed the car has stopped the brakes are supposed to feel firm.
When I am at a decent speed 60-65mph and I need to brake.. I have to double or triple the length to even start to stop.. at that point "the hand starts to close" by the time I get to a car in front of me.. the hand has mostly closed but im not stopped yet. The worst part about it.. when the car has stopped about 98% the hand has closed but the bones through the skin are making a GRINDING type of sound.
I dont know exactly what is wrong.. When I had the car in for an oil change.. I guess they check everything.. measured the tire tread depth and brake amount and all. But I.. dont think they did it "properly" cause... theres no reason why I should feel a grinding sound when the brakes have more then 50% on them.
This is my second Accord. I had a 92 4dr Lx with 231,180.1. And that car didnt have the best brakes either.. but I believe it was because of warped brakes. (The wheel would shake at a high speed stop.)
I also dont understand.. why did both cars.. not have BACK BRAKES?? Is it cause they were both 4cycls.. vs 6's?
I do hope someone can help me.. as I want to take it into a dealership (there is a warranty) but brakes wouldnt be covered.. and I dont want to get raped.
Old 02-28-2007, 02:18 AM
Re: cant stop
thank you thank you thank you because i didnt know how to put it but you worded it perfectly! ive been told honda isnt exactly known for their braking systems but if you got a V6 that kicks like a mule (plus an upped sticker price) youd think theyd do something to bring ya down from all that speed.
my pads like accordsforall's had a bunch of padding left and they are making a grinding noise too from a high speed stop
ive never had to use them but ive heard this is what the ABS sounds like under emergency braking, even tho i wasnt making an emergency stop. this might be blasfimy but im bout ready to throw some Toyota Tundra brakes on this thing.
Old 02-28-2007, 08:40 AM
Re: cant stop
Hmmmm
Ive had the 00 Accord 4cycl 4dr for about 2 months now.. and while I love so much about it, cornering, driving in the snow, handling.. and the driving position... I think my love for the brakes are far far down in my love for the car... keep in mind Im not thrilled about the... styling either.
But as far as.. ABS goes.. Ive known about ABS being installed on cars since it was introed in luxo cars about 1990 model year.
And If I was using the ABS... it would kick back madly.
From what I remember.. the there is a loud screaching sound when I come down at high speeds.
I know a few things.. I know I might need to get the brakes done, either left or right. And I might need the rotors sanded down.. and or the linings. And then there are the pads. But... I really dont want to bring the car in.. for fear of bein raped.
But as far as clenching my hand.. and brakes... I will put it this way.. when my hand is closed.. and clenched, the brakes often feel too tight or theres nothing there.
I also think... if I didnt have any pads, the car wouldnt stop at all.
R.I.P to my 92
I am the Accord man and I approve of this Message.
Accords for all
Accords for all
The PRELUDE to Life ACCORDing to the VIGORous and LEGENDary Accord rules, all else blows.
Ultimate Honda Legend Wagon
A current version of the Honda Accord AERODECK / Shooting Brakes as inspired by http://www.pestalozzi.net/sb/a_index.html
Old 02-28-2007, 08:57 AM
Re: cant stop
You guys' compaint is kinda typical of a couple of things.
Have you looked at the rotors in the rear? I don't know if Hondas have any problems, but GM 4Wdisc systems had a long-standing problem with siezed hardware in the rears, the back brakes were not doing a damn thing back there....easy to spot, because one or both sides of the rear rotors would have surface rust on the friction face, since the brake pads were not cleaning them off...
Also, I've run across some similat complaints on cars that were previously owned by older drivers (I know this because I did work for both the seller and buyers) who tend to make loooonnngggg drawn out stops...the bias is to the front brakes, when you brake like that, only the front apply...over time the rears will sieze, and the front is doing all the work, which is not too noticeable on FWD cars, until you really NEED to stop, then you get what you are describing, a nice solid but ineffective pedal...many times a lot of warpage of the front rotors occurs due to overworking and excess heat, and the rears will grind as they try to apply but only make light dragging contact with the rotors...
Some stuff to consider. See if that jives with what you have....
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made...
...empty gun rack.
Old 02-28-2007, 11:27 AM
Re: cant stop
Hmmm
I dont have rear brakes.. and havent on either the 92 I used to have.. or the 00 Im driving. And I dont like to make long drawn out stops.. but I have to in order to scrub the excess off.
R.I.P to my 92
Accords for all
Accords for all
