Old 02-04-2007, 09:56 PM
korndogg's Avatar
korndogg korndogg is offline
Send a message via AIM to korndogg Send a message via MSN to korndogg Send a message via Yahoo to korndogg
another warped rotor problem
Well I know alot of silverado's had this problem. And I use to be a brake tech and saw it all the time at the shop I worked at. Has anyone solved this problem?? I just replaced mine about 8 months ago and they are warped already.
1968 Camaro 327
1999 Silverado 1500 Z71 LT
{o,o}
|)__)
O RLY?
http://www.cardomain.com/id/korndogg002
Old 02-05-2007, 06:37 AM
Sonny01's Avatar
Sonny01 Sonny01 is offline
Re: another warped rotor problem
I have a 2000 5.3 and have had my share of brake problems...I now have Brembo cross drilled rotors on the front with Hawk pads and new stock rotors/pads in the rear. I use the Super Blue brake fluid I think it is, I'd have to look at the can for sure but my truck stops better now at 96k miles then it ever has and I got it at 35K with all new the rotors/pads and I changed them once at 69K with Brembo slotted rotors and ceramic pads front and back and couldn't tell the difference over stock.
Old 02-05-2007, 11:51 AM
silverado122775's Avatar
silverado122775 silverado122775 is offline
I have over 156K on my truck and I have never had any brake problems.. ame rotors and have only needed to replace the brakes once.. I know I know. But I swear by GM Ceramic pads.. best Pads I have ever had on a truck.
2000 Silverado Z71, 5.3L, K&N GenII Air Intake, Y-pipe Exhaust (no muffler), Bosch Platnium +4 plugs, 242k miles and still running.
Old 02-06-2007, 11:22 PM
tykrz's Avatar
tykrz tykrz is offline
Wheels need to be tightened with a torque wrench in two steps following the proper criss-cross pattern to the proper specified torque value.. If not, you risk warping the rotors. Impact guns are a big no-no. Also, the reverse order has to be followed when removing a wheel.
Warped rotors are almost always result from improper and installation technique.
Old 02-06-2007, 11:34 PM
korndogg's Avatar
uhm well I torqued them myself. And yes I know how to do it. I was a mechanic. Thats not the reason they warped.
1968 Camaro 327
{o,o}
|)__)
O RLY?
Old 02-06-2007, 11:41 PM
tykrz's Avatar
The only other thing that will warp them is overheating the brakes. Maybe the calipers are not fully releasing creating excessive heat.
Old 02-06-2007, 11:47 PM
korndogg's Avatar
brand new loaded calipers when I did the brakes. I have to check the rears out. My guess is that the rears have an issue and the fronts are overworking.
1968 Camaro 327
{o,o}
|)__)
O RLY?
