Go Back   Automotive Forums Car Chat > Ford > Bronco
Old 02-04-2007, 08:13 PM
bigdawg703 bigdawg703 is offline
Push button 4x4 change to Manual?
Is it possible to change a push button 4x4 1990 bronco with 302 and auto trans, to a stick shift transfer case and manual locking hubs?
Thanks
Old 02-25-2007, 08:33 PM
302exploder 302exploder is offline
Send a message via AIM to 302exploder
Re: Push button 4x4 change to Manual?
changing to manual hubs is easy, just buy some warn or milemarker hubs for a dana 44. if your auto hubs have the three bolt caps, you need the conversion kit, if you have the five bolt caps, you're fine.
manual transfer case is a little more complicated. you'd need the manual transfer case, shift linkage, shifter, modifying the floor.
to answer your question: yes, hubs easy, transfer case is a little harder
