Go Back   Automotive Forums Car Chat > Chevrolet > Malibu
Old 02-04-2007, 08:46 PM
bcopeland bcopeland is offline
Catalytic Converter
What are the signs that you need a new cat? Would you have an error code stored or will it just be drivability problems. If so, then what error code or what type of drivability issue?
Old 02-06-2007, 10:32 AM
dwalmop dwalmop is offline
Re: Catalytic Converter
You might get a code about inefficient catalyst or something, but other signs are a groggy engine, smell of rotten eggs, rattling from the cat.
Great quote: "I am noticing a loud fuel odor"
Old 09-28-2007, 09:29 AM
Robert Kerbe Robert Kerbe is offline
Question Re: Catalytic Converter
Does the rattling noise go away when the car warms-up?
Old 09-28-2007, 10:23 AM
cmhj2000 cmhj2000 is offline
I've seen cat rattling come and go, hot or cold.
Check my home page for lubrication help.
Old 09-29-2007, 12:17 PM
Speedy_1234 Speedy_1234 is offline
Send a message via AIM to Speedy_1234 Send a message via Yahoo to Speedy_1234
One of the thing you might look up is gas millege put a full tank drive normal do you waste more gas then before or is the same. See the conveter whats is inside looks like a beecomb but since the pores are getting clog with the waste of the fumes it becomes more harded for the exhust to come out easy then before so therefore there more use of gas in order to let the exhust go out easy. But what year is the car , what i been told after ten year it recommended to change it.
opcorn:
Old 10-02-2007, 04:09 AM
Macgyver2484 Macgyver2484 is offline
You can just take it off and add some pipe in place of it. It's a great way to add horsepower and eliminate your problem.
Old 10-02-2007, 08:09 AM
Ahhh But the check engine light would come on and even if you try to take it off it will come back it will give you the code P0420 why because in mine i took it off and just put a pipe on it but even if i try to erase the code it would come back on
opcorn:
Old 10-02-2007, 10:49 AM
Hmmm, there has to be a way to get around that. Usually you can buy an O2 chip/wire that you plug into where the O2 sensor is actually supposed to go which keeps that light off.
Old 10-08-2007, 12:17 AM
ausdee ausdee is offline
Can the catalytic converter stop car from starting.
i notices rotten smell in car, car gives less mileasge around 20 in city ( i thought this may be due to v6).
I cant start car. Although looks like anti-theft is flashing, but i am not sure if it was when i tried to start it.
Any ideas.
Old 10-08-2007, 12:26 AM
No, it cannot (unless it's completely clogged, which is unlikely). Do the basic tests to narrow it down. Check the spark, fuel, and compression and then head off from there.
Old 10-08-2007, 07:52 AM
Well no but check you if it really had the theft light on if it did well you put the key in the ign. on don't start it all doors closed wait ten min. the light goes off the start the car
opcorn:
Old 10-10-2007, 08:03 PM
stratford_boy stratford_boy is offline
so the car starts or not?? be specific.
Old 10-11-2007, 08:17 AM
Who Me?
opcorn:
Old 10-14-2007, 06:14 PM
I think he means Ausdee.
Old 10-14-2007, 06:52 PM
Yes, ausdee. You have to be very specific, since I can't be there to ask you a question....does it start or not? crank or not? what exactly happens right down to the nitty gritty...no such thing as too much info!
