Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 02-04-2007, 07:05 PM
modification_inc's Avatar
modification_inc modification_inc is offline
Send a message via MSN to modification_inc
97 vic lx
I am looking at buying a 97 crown vic lx with 102547 miles for $2700. any problems with this car I should look out for? Thanks for your help.
Old 02-05-2007, 07:07 PM
hotrod_chevyz's Avatar
hotrod_chevyz hotrod_chevyz is offline
Re: 97 vic lx
watch out for problems with these:
1: noisy or loose steering. Worn bushings and ball joints.
2: ABS & check engine light.
3: interior controls and features
4: engine or transmission leaks or noises.
Talk them down on the price if possible. If it has air suspension walk away. Depending on the options the car has makes a difference in its overall value. The miles arent too bad but still leave a possibility for front end problems and other problems.
Old 02-05-2007, 08:32 PM
1996Chreokee 1996Chreokee is offline
Re: 97 vic lx
make sure you check the frame rails in the front over really good for rust, breaks and cracks... by the front wheels... jack it up and take the wheels off, get a real good look there... i know it sounds crazy but they have a major problem there because the road debris collects there...
good luck
Old 02-06-2007, 08:59 AM
sheebeehuh sheebeehuh is offline
Re: 97 vic lx
Check to see if it still has the original, all-plastic intake manifold. If so, there's a good chance it will need replacing at some point (preferably BEFORE it blows).
More info here....
http://www.autoclinix.com/Manifold.htm
