Old 02-04-2007, 07:38 PM
ViperJ's Avatar
ViperJ ViperJ is offline
Send a message via MSN to ViperJ
LT1 Block
So, I am looking at possibly building a LT1 engine up then swapping it into my car. I found an ad for this
"I have a 94 buick roadmaster with a Chevy 350 v8 LT1 that was in a rear end collision in december 05. it ran and drove fine so i drove it for another year and now its time to part with it. Motor is still in car good tranny and diff as well. take the whole thing. it has been parked for a month and now it won't start, i think it's got plugged fuel injectors. I put some marvel mystery oil in the gas tank a few days before it stopped running probably disloged some nasty stuff in the fuel lines. Motor has 215k on it and was pulling real strong sounds great and quiet when running. With that kind of milage you might want to go through it before putting it another vehicle or just replace the seal around the oil pan where it leaks alittle bit. would be awsome in a little S-10 pickup or maybe a datsun Z. "
What do you think? Sound good or is $400 to much for that? I would be doning a full rebuild and then swapping into my car, although it will still be a daily driver.
White 07 STI, Bone stock for now
Old 02-04-2007, 08:51 PM
1986Z28's Avatar
1986Z28 1986Z28 is offline
Has a Camaro
Send a message via MSN to 1986Z28
Re: LT1 Block
you will want to rebuild it, and from what i hear the cast ron LT1 heads also outflow the aluminum ones and at 400$ you cant really go wrong
Formerly Blownalcoholboy
1986 Z28, 400ci SBC, Twin borg warner billet S467 turbos, Reid case powerglide, Moser 9". Holley EFI, Boost Leash. 950RWHP on pump gas, 1200rwhp on race gas (22 psi)
Best ET 1/4: 8.35 @ 170mph (275 drag radial)
Best ET 1/8: 5.44 @ 132mph (275 drag radial)
Best 60': 1.31 on the back tires (275 drag radial)
AF User Rules/Guidelines
http://www.automotiveforums.com/vbul...uidelines.html
Old 02-04-2007, 10:48 PM
ViperJ's Avatar
Re: LT1 Block
Yeah, I would be getting it and rebuilding it. New seals, pistons (for either boost or spray), heads, that type of thing. It would be my first rebuild but my buddy is a mechanic and build the motor/tranny for his chevelle. What all should be replaced? I guess I will tell you the plan first. I want a 400ish hp car, I guess it probably then wont be daily driver but if I can get good gas mileage then I would drive it daily
Old 02-05-2007, 10:20 AM
1986Z28's Avatar
Has a Camaro
Re: LT1 Block
LT1's are easy to make power with, id sugest you keep the stock cast heads, like i said they outflow stock aluminum ones, and with some porting they can make some power. run a bigger cam, something like the LT4 cam(wit matching springs) would be a great cam i think, you probaly have to punch it .030over so if you want to spray it youll want to run a flat top forged aluminum piston, upgrade you main and rod bolts to ARP's, run some bigger injectors maybe a 58MM throttle body, and a good tune id say you could probaly hit 400hp
Old 02-05-2007, 12:18 PM
ViperJ's Avatar
Re: LT1 Block
What do you think about this package?
http://eportworks.com/LT1LE1.htm
Old 02-05-2007, 09:12 PM
FormulaLT1's Avatar
FormulaLT1 FormulaLT1 is offline
Fight the powwa!!!
Send a message via AIM to FormulaLT1 Send a message via MSN to FormulaLT1 Send a message via Yahoo to FormulaLT1
Re: LT1 Block
Lyod is a good guy. I sold 3 or 4 sets of heads to the guy and many people who he did port work for swear by the guy. I also agree on it totally being worth it.
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart.
Mods: Weight reduction (I don't wear underwear)
Old 02-06-2007, 11:20 AM
1986Z28's Avatar
Has a Camaro
Re: LT1 Block
they look like nice heads to me, they flow about the same as my new ones also
Old 02-06-2007, 01:24 PM
doodad's Avatar
doodad doodad is offline
Send a message via AIM to doodad Send a message via Yahoo to doodad
Re: LT1 Block
i am about to build mine up but it is damn cold!!!
Old 02-06-2007, 10:31 PM
philly rs's Avatar
philly rs philly rs is offline
Send a message via Yahoo to philly rs
Re: LT1 Block
yeah i will agree with the heads...i have a set im having worked myself, and from what i hear they will be the ish when i get them on the car with the new engine. thats a sweet deal for 400 bucks, hell thats project starter cash right there
Your import sounds like my ass after a night of mexican food..
And spraying aint cheating, its brining a gun to a knife fight!!
yeah, its a v6 RS...never mind the f1 badges lol
HYPSI87 u will be missed
