Go Back   Automotive Forums .com Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 02-04-2007, 07:23 PM   #1
the1cov
Will not start, no signal to injectors
So I replaced the head, and now the engine will not start. It does turn over, and is getting spark, and fuel. But the injectors are not getting the signal to spray fuel. I have trouble shot the problem a little. Is their anything I could be missing, like some hidden relay or fuse, or maby something I over looked.
the1cov is offline   Reply With Quote
Old 02-04-2007, 07:24 PM   #2
J-Mech
Re: Will not start, no signal to injectors
what are we working on?
J-Mech is offline   Reply With Quote
Old 02-04-2007, 07:27 PM   #3
the1cov
91 Eagle talon tsi awd
Old 02-04-2007, 07:33 PM   #4
J-Mech
How do you know the injectors are not getting signal?
Old 02-04-2007, 07:45 PM   #5
the1cov
noid light, and I listened for the pulse through a screwdriver.
Old 02-04-2007, 08:25 PM   #6
J-Mech
Cam sensor not plugged in? Module. ECM fuse?
Old 02-04-2007, 08:33 PM   #7
the1cov
Cam angle sensor is pluged in. Were is the Ecm fuse located.
What is Module?
Old 02-04-2007, 08:36 PM   #8
J-Mech
It may not have an ecm fuse, if it does it would be with all other fuses. The module i'm referring to is the ignition module.
Old 02-04-2007, 09:05 PM   #9
the1cov
There are a couple different modules, I think they all have to do with the spark. There is a fuel injection control relay but that is good. There is also a ignition switch that goes behind the ignition lock cylinder. but I dont think that has any thing to do with the repetive pulse to the injectors. What do you think.
Old 02-04-2007, 09:08 PM   #10
J-Mech
No i'm pretty sure it doesn't. UHHHHHHH that year and make is playing with my memory. Sorry bud I'm not sure where the module is. Do you have access to a scan tool?
Old 02-04-2007, 09:19 PM   #11
the1cov
Not sure what you mean by scan tool, sounds like I need to buy one. Could you please explain.
Old 02-04-2007, 09:24 PM   #12
J-Mech
A good scan tool is a VERY expensive piece of automotive equipment. What I'm interested in is if there are any codes being saved in the computers memory.
Old 02-04-2007, 09:50 PM   #13
the1cov
Nope checked that earlier today. The only code was the coolant temperature sensor. I was hoping that would help me out but sence there was not a important code, I am at a dead end. Unless their is something I am mising or maby the wires got cut some how. I am trying to look up diagrams right now.
Old 02-04-2007, 09:56 PM   #14
J-Mech
How many injectors? MPFI or sequincial? or throttle body. Sorry eagle talon is a little off my memory. Been a while since i've seen one.
Old 02-04-2007, 10:17 PM   #15
the1cov
4 injectors, throttle body. If it were to help it is the same car as the Mitsubishi eclipse everything is the exact same.
