Old 02-04-2007, 06:13 PM
mitsu3kgt mitsu3kgt is offline
Motor mount inserts???
I am thinking of buying motor mount inserts. How hard are they to install?? Can anyone give me some directions on doing them? I will realy appreciate it.
Old 02-04-2007, 10:51 PM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
Re: Motor mount inserts???
i assume you are talking about polyurethane inserts? it shouldn't be that hard, but a press would make installation much easier. as for removing the rubber in the stock mounts, i've heard of ppl lighting it on fire.
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 02-05-2007, 07:36 AM
Im going to try doing them without a press. So you heard that to get the old inserts out, people burned them out? I guess I will try that. Do you know anyone that has done inserts, that I can ask questions?? I was also looking at Maximal performance solid motor mounts. I have heard good things about them, but I just wanted to ask people what they think. I don't really care about the vibration, I just want to know are they worth $210.
Old 02-05-2007, 09:07 AM
Linebckr49's Avatar
heck yes they are worth every penny. i just purchased some solid mounts and installed them last week. quite a bit of vibration, but they do the trick. my exhaust used to hit my car when i mashed the throttle (i suspected a bad motor mount to be the culprit). now the exhaust doesn't thump anymore. motor mounts did the trick.
93 3000GT base
Old 02-05-2007, 06:50 PM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
You really do need a press to do the inserts. They dont just fall into place.
Old 02-05-2007, 08:22 PM
Hotshot8792 Hotshot8792 is offline
go drive a V8 and lets see you talk about solid motor mounts having vibration
the Z28 i used to drive had move vibration with stock mounts than my 3/S does with solids
Daily Driver: 2004 Jeep Grand Cherokee Special Edition
1994 Mitsubishi 3000GT SL-TT Automatic - Black
3.05 L Arias Forged Pistons, Pauter Forged Rods, DR Stage 3 heads, 3SX TD05 kit w/ E16G's, CX Racing FMIC, 550cc injectors, Walbro 255lph pump, + supporting mods
1994 Mitsubishi 3000GT VR-4 - Black
Intake & Boost Controller so far
2006 Sea-Doo RXP Supercharged, Updraded SC, IC + supporting mods
Old 02-05-2007, 08:58 PM
Linebckr49's Avatar
i've driven and ridden in many a V8. but the vibration in my 3S is still greater. everything in the cabin rattles. granted, i have the cat removed right now (let a friend borrow it for emissions testing), so that may contribute to the ill effect i'm experiencing. also, my idle has decided to chill at 1400rpm. so when i fix the idle and put the cat back in, i'll report back.
but i'm probably gonna put my good rubber stock mounts back in (only front mount was bad) and leave the one front solid mount in there. right now, its just not a comfortable daily driver. i can deal with a very tight suspension and bumpy roads, but this extra constant vibration puts it over the top. however, when i accelerate at WOT, it sounds like i have a blower that is whining like crazy. makes my car feel like a V8 on the inside. its pretty sick, but it just takes the comfort factor way down.
93 3000GT base
Old 02-05-2007, 10:28 PM
Thank you for all the information, Im going with the solid mount. I don't care about the vibration, because its not my daily driver. And they are a lot cheaper that Poly mounts.
Old 02-06-2007, 12:30 PM
Zeiss's Avatar
Zeiss Zeiss is offline
I have polys and they rock
Bye V8...
Old 02-06-2007, 01:13 PM
Linebckr49's Avatar
Im going with the solid mount. I....And they are a lot cheaper that Poly mounts.
that's what made me decide to go with solids...the price. $210 (no core charge) compared to $329 + $300 core charge. the 3SX price is absolutely RIDICULOUS. 300 core charge? gimme a break. you know the poly inserts are dirt cheap, and they probably making 500% profit on these.
/rant
93 3000GT base
Old 02-06-2007, 06:02 PM
Igovert500's Avatar
blue + red light magnet
There was a guy on 3si who made his own poly mounts for dirt cheap. I'll try and find hte link.
Edit: Here it is for you DYI'ers
Edit #2: After reading the entire thread (didn't last time) it appears these have longevity issues. So read the entire thread before trying it.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 02-08-2007, 01:59 PM
I order the front and rear motor mounts, because I thought it would help me more than the side and trans mount. I'm mainly using my car for more drag than auto crossing. I have another question about the TC bracket they sell. Will it strengthen my TC housing and help keep it from breaking, or is it a waste of money??? I was looking at the Maximal and Nelson performance brackets. Then Nelson one looks like it will strengthen it better, but if the Maximal is good I will rather spend $80 than $250.
Old 02-08-2007, 04:11 PM
AutostradaVR4 AutostradaVR4 is offline
any bracket is better than nothing, but if you're racing the car, brackets are just band-aids IMO. I know its way more expensive than a bracket, but if i was going to race my car, i would go for one of them shiney new billet TCs
Formerly BlinkRA182
--VR-4-- --09 Lancer RALLIART-- --Me--
Old 02-08-2007, 10:24 PM
Where can I find a billet TC???
Old 02-09-2007, 03:09 AM
Linebckr49's Avatar
there were only a few billet TCs produced. then there was a group buy for a few more. however, another company has produced a stainless steel TC, which is as much of an improvement over the stock TC as the billet one is. 3SX carries the stainless steel TC.
93 3000GT base
