Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 02-04-2007, 03:23 PM
4g63gst20 4g63gst20 is offline
Send a message via MSN to 4g63gst20
safc2 installation
i just got my safc2 from a member in here, and i have it in my car now, i followed the directions on vfaq, and the intructions tell you to use the yellow and white wire. But i checked tuners and found another site that says to use the pink one and orange, so now i'm like WTF!!! which one do i trust ? I have it installed using the white and yellow but i'm just wondering, Which one is the right one?
here is the link to what i used http://www.vfaq.com/index-main.html
here is the link to the site that tells you to use pink and orange http://my.prostreetonline.com/t105.htm
Also, where do i go to the menu for the corrections? i have 510cc injectors. and i just wanna get it to idle right and drive so i can take it to the dyno.($75/hr with them doing the tunning)
-MODS-
Autometer Boost,Oil Presure,And Water Temperature Gauges./Geddy Turbo Tmer/Eibach Sportline Springs Matched With Adjustable Iluminas 4 Corners/Konig 18" On Nitto Extreme 555/ACT 2100 PP with Street Disc/Extended Push Rod/Urethane Motor Mounts/XS Power FMIC. 28X10.5X3.5/Greedy Type RS BOV/ evo3 16g Turbo/MBC At 18PSI/Bian Crower 272 cams/SAFC2 With 510cc Injectors/Walbro 190 FP/
1/4 mile=14.3@103MPH
Old 02-04-2007, 03:40 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Re: safc2 installation
I would trust vfaq over some other website being as it was written by DSMers. And if it doesn't work, you can always switch it.
95 Talon TSI AWD
97 Eclipse GST
Old 02-04-2007, 04:06 PM
now i just found this http://www.vfaq.com/index-main.html on vfaq and it says to use the pink and orange, and i also noticed that my hz is not changing, it stays on 3 all the time, so i'll try swithcing when is not too cold.
-MODS-
