Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > F-Body Problem Diagnosis
F-Body Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 02-04-2007, 10:17 AM
griff305 griff305 is offline
92 RS wont run????
I jumped the starter enable relay and it is cranking the motor. Injectors are pumping but it still does not run?????
Old 02-05-2007, 02:50 AM
Morley Morley is offline
Re: 92 RS wont run????
You need 3 things to make an engine run...fuel (you say the injectors are firing), Air (lots of that here) and spark...you are probably missing spark.
Old 02-05-2007, 06:00 PM
i checked #1 cylinder and it was getting spark ill have to pull and check the rest
Old 02-06-2007, 01:44 AM
What color was the spark? It should be blue/white. If it is red or deep orange, it is a weak spark.
Old 02-06-2007, 04:55 PM
it was a good spark but i have yet to test the rest
Old 02-07-2007, 12:03 AM
smalltownjms smalltownjms is offline
Hi
You have spark and fuel and air.............i have a 91 rs and had the same problem. I went through all the steps and never figured it out. I took it to my mechanic and it ended up being my injectors.Even though they would fire while it was turning over,when i sprayed starting fluid in it and forced it to start they would quit firing........You might want to see if you can start it with starting fluid then if it starts ....get some injectors
Old 02-07-2007, 08:45 PM
was your vats hooked up proplerly. or you your security light on
Old 02-08-2007, 11:00 PM
If the engine will turn over, as in the starter engages, then VATS has nothing to do with the problem. VATS only prevents the starter from engaging.
Old 02-09-2007, 09:51 PM
i know that my vats is not hooked up properly i jumped the starter enable relay so it would crank. The Vats wont put out a sufficient amount of volts to crank the motor if its engaged
Old 02-10-2007, 01:32 AM
If you have jumpered the starter enable relay, then you have effectively bypassed VATS.
Do as suggested and have someone crank it over and spray some starting fluid down the TBI. If it starts and your injectors are indeed pulsing, then you probably need new injectors. But first verify that the fuel pump is running and pumping out fuel, and then for good measure, replace the fuel filter. If you have good fuel flow up to the injectors, then they need to be replaced.
