Go Back   Automotive Forums Car Chat > Pontiac > General Discussion
Old 02-03-2007, 11:46 PM
wh1skea's Avatar
wh1skea wh1skea is offline
Send a message via AIM to wh1skea Send a message via Yahoo to wh1skea
Engine Code question
I have a 400 built in 1972 (casting # 481988), and am trying to figure what it originally went in, so maybe I can sell it. The engine code is 22A162973. I know the first 2 is to show its a Pontiac engine, the second 2 shows it was built in 1972, and the A is the assembly plant. From what I have found so far, the A shows that it was built in Atlanta, GA. So, my question is what cars would have used this engine? Also, it has a YS with 0351718 above it.
1983 Nissan/Datsun 720 Kingcab
Engine: Z24
Transmission: 5-speed
Engine mods: stock
other mods: 84 720 ST bed
-insert pic here-
Old 02-05-2007, 01:00 PM
MrPbody MrPbody is offline
AF -Advisor
Re: Engine Code question
Well, the "YS" is the application code. YS was used for a slew of engines over the years. If you could supply the casting date (4-digit, alpha-numeric code near the distributor), it would be a lot easier to narrow it down. '72 YS would probably be a GTO or LeMans 400 with auto trans, but I can't be certain without that date! It DOES fall into the "nothing special" 400 category. By '72, 400s were pretty much all the same with a few minor differences. Good candidate for a stroker!
Jim
Old 02-05-2007, 08:35 PM
wh1skea's Avatar
The date code is A272.
Engine: Z24
Engine mods: stock
-insert pic here-
Old 02-15-2007, 05:45 PM
wh1skea's Avatar
Another question is what color should my engine be? The guy I bought it from painted it black.
Engine: Z24
Engine mods: stock
-insert pic here-
Old 02-22-2007, 08:22 PM
69goatfarmer's Avatar
69goatfarmer 69goatfarmer is offline
The color for the '72 engine is a sky blue. Duplicolor makes an engine enamel in a rattle can that is very good match, I believe the part number is DE1610. This is usually avalible at most decent auto parts stores. There is also a silver blue that Pontiac used but that wouldn't be a correct color for the '72.
58 Cushman Scooter
69 GTO Conv 400/4sp
66 GTO Hardtop 428/Auto
75 Honda CB550
04 Grand Prix GTP Comp G
