Go Back   Automotive Forums Car Chat > Honda > Integra
Old 09-29-2002, 11:27 PM
brianized brianized is offline
Question Battery light goes off and on?
Hay,
I got a great car for 2,700.00!
And I am having proublems with the charging system.
When there is a load on the system the battery light comes on?
And then goes off when the r's come up?
I have replaced the battery. All of the parts are orginal. The alt. is boscH.
seems to be putting out voltage?
1990 Acura Integra 3 dr. 5 speed
Old 09-30-2002, 05:45 PM
blowngsr blowngsr is offline
Send a message via AIM to blowngsr
check your altenator & alt, belt tension
Supercharger $2000, Destroying V-8's PRICELESS!!!!!!
00 GSR/JRSC/ICEMANCAI/DCHEADER/TESTPIPE/TANAUBEEXH/SKUNK2CAMGRS/street tires&11psi=13.6@105
Old 10-03-2002, 01:30 AM
Talking Battery light
Belt is tight and puttin out volts.
They said that the alt was good the battery was bad. Ill check the alt again. I gess that you just have fix it your self to do it right. Replaced the battery (with the best) and it still does it but not as often. What do you think.
Old 10-07-2002, 04:50 PM
sounds like a plan.
Old 10-07-2002, 10:08 PM
Talking I fixed it for $7.52 at TRUEVALUE HARDWARE!
I got the alt. loose in the engine cavity. Removed the cover plate and the brush holder. Unsolderd the warn brushes and found som for a vacuum at T.V. The car works great. So next time you need a alt for your ask the dick behind the counter for a set of brushes and then see how he reacts?
Brian
keep the rubber side down and the pretty side up!
