Old 09-29-2002, 10:30 PM
nittanys1's Avatar
nittanys1 nittanys1 is offline
Send a message via AIM to nittanys1
Exclamation I think I FRIED my amp....
Ok here how it goes...
Last night when I turned on my car i heard this dull pop and "sphh" and then my radio turned on....It started to have heay loads of static and i thought I had it on a bad station, so I switch it to the CD changer. The static was still there. So I checked EVERY fuse that could be a problem and have recently rewired my system connected to the head unit and everything sound fine...my Mini Disk works along with the CD changer.
Upon taking out my head unit to unwire/rewire it I noticed that the ground to the amp that comes out of the head unit had came unconnected (the wires were crimped together throught some addaptors) So what I'm wondering is if my asumptions are correct....
Old 09-30-2002, 12:59 AM
SilverY2KCivic's Avatar
SilverY2KCivic SilverY2KCivic is offline
Cali Guy
Send a message via ICQ to SilverY2KCivic Send a message via AIM to SilverY2KCivic Send a message via Yahoo to SilverY2KCivic
Sounds like maybe just a bad ground problem. If I fuse is bad, it'll cut ALL power to whatever it's for. Did you try it all out after you re-connected the ground wire, and if so, what were the results?
Silver '00 Civic EJ6 Coupe
PureHonda original member since Feb. 2000
D-series revolution For pics of my baby, click here!
All rights reserved... All BITERS served!
"The last time you had THIS much fun driving a car, it cost a quarter, and gyrated in front of the supermarket."
i have yet to see any well done imports around here. most are road toilets driven by some high school punk -Drift
hessemer69 on AIM
Old 09-30-2002, 10:31 AM
nittanys1's Avatar
yeah i plugged it back up and it restarted the system then the static kicked back in.....
