Go Back   Automotive Forums Car Chat > Cadillac > Deville
Old 02-03-2007, 04:27 PM
frank1492 frank1492 is offline
2001 DeVille Multiple Misfires Solved! Now New Problem!
Caddy Daddy and others:
Code 300 Multiple Random Misfires traced to a bad front (?) spark coil. Car runs perfectly now. However there is a new problem.
When I was setting the parking brake last night, it suddenly went to the floor! I assume the cable broke.
Could anyone tell me whether this is something that a good station could fix? Most won't touch certain things on this car, like plugs.
Also, this is a brake that automatically releases when the car is put into reverse. I was wondering if that would complicate the repair process or make it more expensive.
Thanks to CD for your previous help! Future help much appreciated!
Frank
Old 02-03-2007, 05:41 PM
caddydaddy caddydaddy is offline
Re: 2001 DeVille Multiple Misfires Solved! Now New Problem!
Yes, that sounds like a cable that snapped! The regular service brakes work fine, right? I don't see why a good shop wouldn't be able to fix the cable. The automatic release is just a vacuum operated mechanism that does the same as pulling a release handle. So if that is working ok, then the shop doesn't have to worry about that, and just fix the cable.
Good luck!
2000 Cadillac STS
2005 Cadillac Escalade
2008 Triumph Sprint ST 1050 ABS
