Old 02-03-2007, 03:19 PM
compaqpunch compaqpunch is offline
20 Psi!?!
I just picked up my 1992 dodge stelth TT, I guned it and the aftermarket boost gage read 20 PSI!! so i turned the boost controll down all the way and it still did not fix it. (clock wise) Any ideas? boost leak? ext
Old 02-03-2007, 05:52 PM
Igovert500's Avatar
blue + red light magnet
Re: 20 Psi!?!
A) are you sure the boost controller is in right
B) pressure test, presssure test, pressure test...
C) does it have a normal vacuum line running to it, or one of those plastic autometer lines that pinch alot. When I had one of those in, I was getting all kinds of weird readings until I switched to a normal vacuum line.
D) I havn't looked at my mbc in awhile, but you wanna back the screw out to turn it down...which means it's probably counterclockwise to turn it down. When it's almost all the way out, you should be at wastegate pressure (~7psi)
E) Are you datalogging?
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 02-03-2007, 06:25 PM
Re: 20 Psi!?!
a)yes, pretty sure i did not install it but it appears to be correct.
b)How do I do a pressure test exactly?
c)I'm not sure wat normal ones are cuz i never had a turbo car before, but it has thick rubber hoses.
D) http://www.turboxs.com/faq/tyrboxsstd.htm -controller. is says clock wise for down i think its a wierd one.
E)no.
Any ideas? I dont feel safe driving it when it spikes soo high on boost....
Old 02-03-2007, 08:20 PM
Hotshot8792 Hotshot8792 is offline
Re: 20 Psi!?!
what turbos are you running? Just curious. Anyways, my guess is that your wastegates are disconnected. Doing this will cause a slight boost leak, but at the same time your turbos will be spinning as fast as possible which could cause a 20 psi spike. If you don't know where to check, locate each of your turbos. On the compressor side (the side that connects to the intake) look for an additional looking piece that sits on top of the turbo and has a small vacuum hose coming from it. Follow the vacuum hose until you see the end of or get to the boost controller, then make sure the other line is connected to the back of the y-pipe. If everything looks connected then unplug your boost controller and plug the hose directly into the back of the y-pipe, then go for a test drive. If your running somewhere around 6 psi then something is wrong with the boost controller. If your still running 20 psi, then something is wrong with the wastegates. Those are the only 3 problems that could cause whats happening to you.
Daily Driver: 2004 Jeep Grand Cherokee Special Edition
1994 Mitsubishi 3000GT SL-TT Automatic - Black
3.05 L Arias Forged Pistons, Pauter Forged Rods, DR Stage 3 heads, 3SX TD05 kit w/ E16G's, CX Racing FMIC, 550cc injectors, Walbro 255lph pump, + supporting mods
1994 Mitsubishi 3000GT VR-4 - Black
Intake & Boost Controller so far
2006 Sea-Doo RXP Supercharged, Updraded SC, IC + supporting mods
Old 02-03-2007, 08:40 PM
jason_bet's Avatar
jason_bet jason_bet is offline
Send a message via MSN to jason_bet
Re: 20 Psi!?!
Also look for cracks in the lines.. even if the lines are conected if you have a leak you wont have as much pressure to your wastgate to get it open
Old 02-04-2007, 04:41 PM
Re: 20 Psi!?!
Last night something bad happened. I bypassed the boost controll and took it for a spin. I gave it gass and the boost read 7 or so, but then it bounced to 2 and back to 7 then 0. I looked back and i was smoking bad!!! I was really close to home about 3 miles, so i putted back home. It turns out i leaked all of my oil out of my exhaust and my underbody somewhere by the engine.. The motor only has 2k miles on it. I figured the oil filter fell of so i checked that and it was ok. I think I saw a gasket kinda sticking out of place kindof under the front turbo area. The engine sounded fine getting home and had no unusual sounds, but i lost all of my oil and smoked beyond bad.... any ideas?
Old 02-05-2007, 12:52 AM
Igovert500's Avatar
Re: 20 Psi!?!
Wait you drove home on no oil? Stop driving the car. If you cannot find the leak, get it towed to a mechanic who can.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 02-05-2007, 01:41 AM
vectorspecialist vectorspecialist is offline
Re: 20 Psi!?!
he's lucky that with no oil, he got home, thank god it was only 3miles, no oil in car, or for that matter any engine equals one hell of a bill at the mechanics
Old 02-05-2007, 09:05 AM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
Re: 20 Psi!?!
i agree. there was a guy near me who just finished his TT conversion, drove the car for a few tuning pulls. when he brought it back home, checked the oil, and only 1/2 qt drained out!!! i just helped him swap everything over to his new shortblock. expensive lesson.
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 02-05-2007, 07:00 PM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Re: 20 Psi!?!
20psi is nothing. LOL When you see a 30psi boost gauge pegged hard you know youre hitting some serious boost. LMAO STUPID MBC.
Old 02-05-2007, 08:24 PM
Re: 20 Psi!?!
spray the crap out of the bottom of your car with a water hose, put oil in the motor, and turn the engine on. Look up under the car and see if you can find where its leaking. If you find any oil then you've found your leak
anyways, look around the rear main seal (transmission area) at both turbos, near the oil pump, oil pan, and the heads.
Old 02-05-2007, 08:49 PM
Re: 20 Psi!?!
The oil seems to be coming from the front turbo or right by it. Do you think a hose or something could have got messed up?
Old 02-05-2007, 10:47 PM
Stealthee's Avatar
Re: 20 Psi!?!
Could be the oil feed line
Old 02-06-2007, 07:48 AM
Re: 20 Psi!?!
I am thinking it has to do with the turbo because oil was coming out of the tail pipe as well as up front by the turbo area. Would that cause a huge amount of smoking as well?
Old 02-07-2007, 07:44 AM
Zeiss's Avatar
Zeiss Zeiss is offline
Re: 20 Psi!?!
Id like to help but this sounds like alot of things are going wrong. Where did you get this car from?? Sounds like you got ripped off badly..
Bye V8...
