Go Back   Automotive Forums Car Chat > Mercury > Cougar
Old 02-03-2007, 12:07 PM
jwild1979 jwild1979 is offline
Unhappy 90 cougar dash/radio
I recently bought a 90 mercury cougar 3.8L Yesterday I replaced the stock radio and it was working fine... for about 5 minutes, all of a sudden the digital dash and radio went dead at the same time. I removed the radio and that did nothing. They are not on the same fuse. I checked ALL the fuses in the drivers side fuse box(the only one I know of) and ALL fuses were good. My Chiltons manual has engine wiring but not the wiring for the interior so no help there. If anyone has any ideas or wiring diagrams I could REALLY use the help, I have no speedometer, and cant drive until I do.
Old 03-18-2007, 01:59 AM
rrclyoung's Avatar
rrclyoung rrclyoung is offline
Re: 90 cougar dash/radio
Did you get the proper wiring harness for the car or did you just cut off the plug and splice the radio wires to it. I have an EVTM for the 89 cougar but it shows no common point between the radio and the dash. I am getting ready to replace the radio in mine this weekend, just got all the stuff I need from crutchfield. I will let you know how that goes...
Chuck Young
2006 Chrysler T&C Touring 3.8
2005 Chevy Trailblazer LS 4.2 I6
2004 F150 Heritage
2007 Mitsubishi Endeavor
2008 Pontiac G6
Old 03-23-2007, 02:36 AM
rrclyoung's Avatar
New radio went in fine and did not take out the dash......been in and working now for 4 days. Hopefully you can find the problem with yours. If you did not solder and heat shrink the wires, you might have had a hot wire pop loose and short to the chassis.....that would be the next thing to check
Chuck Young
2004 F150 Heritage
2008 Pontiac G6
Old 12-30-2007, 05:59 PM
cougarkid1 cougarkid1 is offline
its a small 5 amp fuse in the main distribution block under the hood. same problem happened to me. quick fix just hope i can help.
