high carbons when trying to smog
2 days ago I took my 98 Rodeo to the smog place after cleaning my EGR port. I cleared the code and drove it for 53 miles before taking it to smog check. The guy puts it on the machine and it matches the carbon limit but it passes. The part that failed was that after 53 miles, the computer was still reading that not all components checked in so the light was still on. So I decide to drive it to work a couple of days and take it back to pass smog. Well I also put that Guarantee to Pass Smog crap in the take. Well I take it back to smog and now the light is not on of course and it failed the carbon.
So I asked the guy what he thinks it can be. He tells me that it could be a number of things. Being that I have given it a tune up a couple of weeks ago, I know it is not an oil, plugs, or even an air filter. I have had problems with the truck starting. It will keep turning like it is not getting any gas then it starts. So he tells me that since it is hard to start that it could be the fuel pump not keeping enough pressure in the line which could be making the car run too lean causing higher carbons. So I know that my problem could be either the pump or the catalytic converter |
Re: high carbons when trying to smog
Was the truck good and warm the 2nd time you took it in? Did it have enough driving time before the smog for the additive you put in it to circulate?
I've never used any additives such as that, so I'm unfamiliar with it - what's it supposed to do, other then the obvious of what it says. Generally a bad cat on a +96yr will throw a code for the cat convertor - if it's bad. Could also be a bad intake manifold gasket, which is common for your year.
1997 3.2L V6 Rodeo 32" Yoko's, 16x8 MB Wheels, 2" lift, Brushguard, KC Fog's, Loadwarrior Rack On it's way to 185k strong ![]() 2004 3.4L Tacoma TRD off-road 4x4 Double cab 32" Yoko's, Westin Bull-bar, KC Fogs 60K miles
My work is an hour away from home and the smog place is by my house. So yes it was plenty warm.
As for the additive, it is supposed to clean out the system so it runs cleaner. I did run it long enough for it to get cleaned but I am thinking that I should have not put it in unless it failed again but since I was matching numbers 2 days before, I figured I would play it safe. I should have waited. As for instake gaskets. They were just replaced by me since I had the P0401 code and it turns out the that end of the tube in the manifold was blocked. So after cleaning that out and the intake, I put on new gaskets. On my 97 Saturn, I had only a bad sensor error but I knew the cat was bad since I could hear partss of it rattling around. 2 years before I had the cat replaced on it, the guy told me that the carbons were high and that the cat was probably going on it. No code ever for a bad cat. What is the code that would be thrown for a bad cat? |
P0420 - TWC System Low Efficiency Bank 1 or P0430 - TWC System Low Efficiency Bank 2. |
When clogged they will not pass enough fuel for the engine to run properly. Good Luck, Dale |
//bc
1992 trooper 3.2L v6 sohc automatic...as is i love a good intermittent electrical challenge. . .especially when it's someone else's. |
acceleration is fine. It does hesitate a little from time to time but that is when I am going from 40 to 50 or something like that. If I do a hard acceleration it stands strong and gives me everything she has. I have not replaced the fuel filter so I guess I can try that.
I have never seen those codes. The only codes that I have seen on my Rodeo is the P0401 and the P0101. Could an old or dirty fuel filter cause bad fuel pressure? I am guessing that it can. |
I'm thinking FPR or fuel filter as well since the IMG was replaced recently and seems to be running fine.
--Dave 1999 Rodeo LS 3.2 4x4 5 Speed 32x11.50-15 BFG T/A KO 3" Lift - Rancho 9000x Rear No-Slip Locker Flowmaster 2.25" 50 Series There is a very fine line between "hobby" and "mental illness." - Dave Barry |
what are the chances it is the FPR? Is it heard of that they go bad on a regular basis?
That was my plans. Now if only I can get my CC back from the Mrs since she lost hers.
have you removed the vacuum line from the fuel pump relay to see if it has fuel in it?
//bc
Nope but I will now. I take it that it is not supposed to have fuel in it? |
good luck //bc
