Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX
Old 02-02-2007, 11:17 PM
BLK240(coupe)'s Avatar
BLK240(coupe) BLK240(coupe) is offline
Want to swap engines
Ok i have an 89 240 coupe with the stock ka24e and i want to swap in a ka24de. Is there anything major i have to change?? This guy told me its a direct bolt in.... i dont know. i know the tranny is the same.
Need help ASAP
BLK 240sx
Old 02-03-2007, 12:59 AM
nismogt_rfreak's Avatar
nismogt_rfreak nismogt_rfreak is offline
Re: Want to swap engines
For starters, the power steering pump is on the wrong side and the single cam tach won't work with a dual cam motor.
I'm not Emo, I'm an Emotional American.:emo1:
Old 02-03-2007, 02:07 AM
XeVeNskyLiNE's Avatar
XeVeNskyLiNE XeVeNskyLiNE is offline
Turbo makes me emo!
Send a message via AIM to XeVeNskyLiNE
And ECU obviously. If you can find a complete DE with harness and perhaps new motor mounts. I can't speak firsthand since I've never done that swap, but ti'd seem like the whole swap should be pretty straightforward and it shouldn't be too hard to improvise where needed. Needless to say, you're not the first one who's ever done it. So just search the net for a write up.
_______A-10 Aircraft Armament Systems Apprentice vv Can't get my sig right vv
Currently in Davis-Monthan AFB, Arizona MySpace My S14 and DSM
Old 02-03-2007, 03:37 AM
Hit_N_Run-player Hit_N_Run-player is offline
Send a message via AIM to Hit_N_Run-player
personally, i would look at a DE bay and a E bay and see the difference in PS lines. I thought it was only the lines needed from the DE needed to be swapped for the mechanical part. Then i guess you've got the ECU and bits. Other than that it shouldnt be too difficult.
1988 conquest TSI
-Lots of mods, finally finished WOOT!!
Horsepower sells cars,
Torque wins races!
Old 02-03-2007, 04:00 AM
Hmm i dont have the p.s. on right now. i figured i would need an ecu. mabey i sould do an sr20. if im going to do a swap better make it the last one.
BLK 240sx
Old 02-09-2007, 10:49 AM
driftking777's Avatar
driftking777 driftking777 is offline
Send a message via AIM to driftking777 Send a message via MSN to driftking777
ka-t ftw....things you'll need.
1. 91-93 ka24de motor/harness/tranny/ecu combo
2. 91-93 cluster (instrument panel)
and thats it. game over total cost...500 bucks
SR20...
1. $2000-2500 for motor set (all of the above stuff mentioned)
2. cluster $100
4. FMIC (if you custom fab your own...400 bucks)
5. Harness rigging...(free if you do it yourself or aprox. $250 to have it done)
6. 255lph fuel pump. $100
...total aprox 3k if you do it all yourself
now for the same power (or more) for a ka-t.
t25/t28 turbo setup
1. turbo (t25 or t28) aprox 150 bucks for a good one
2. oil/coolant lines $100
3. FMIC (as stated above aprox 400 bucks)
5. SAFCII 150 bucks used
6. ECU tune (to be safe) 250 bucks
7. SSautocrack manifold 100 bucks
8. Just for the hell of it, a heat shield for you brake booster $150
total ka-t setup (including motor setup)....1800 bucks...thats turbo setup AND engine setup. way cheaper...and more power.
just remember, before getting a motor ALWAYS...i mean ALWAYS do a compression check of the motor...if its not reading ATLEAST 165+ all across the board, dont buy it. or rebuild it...depends how cheap you get the motor.
full rebuild on a ka (with aftermarket nearly everything...1800 bucks) then your still in the SR price ball park. and can have a nearly bullit proof motor.
but...thats my opinion
Current cars:
83 RX7: KA-T, t3/t4 turbo,Tial 38mm WG, MR coilovers, 5 lug conversion all around, TII brakes, hydraulic hand brake, 8" rear", 6 point cage, AMS Rebuild kit, Fully ported polished race head, Custom interior, JLine 6LR2 15x8, 16x9.5
Old 02-09-2007, 10:51 AM
and if you feel like spending alittle more turbo240.com just came out with there turbo kit for a good price which is a GAURUNTEED 300+whp.
Current cars:
