Old 02-02-2007, 07:37 PM
BOBAILEY BOBAILEY is offline
Oldsmobile problem
Wife drove her Olds to work today, high was around 6 degrees. Ran fine getting there. Came time for her to come home and when you turn the ignition key it does'nt do anything. Lights and everything else works fine. It was to cold for me to check it out tonight ,but I would like some advice on what to check tommorrow. Thanx
Bo
Old 02-03-2007, 09:30 AM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Re: Oldsmobile problem
Transmission starter interlock swithch.
This prevents the car from starting in gear. Try wiggling the shift lever while turning the key, or bypassing the switch.
Also, try carefully energising the starter motor directly, using jumper cables. If this spins the starter, try energising the starter solinoid. If this works too, then the problem is in the starter circuit.
Old 02-08-2007, 10:57 AM
ShadowWulf2K ShadowWulf2K is offline
Make sure the battery terminal's are tightened. My girlfriend's Oldsmobile has the same problem you described on starting. Make sure those connections are tight.
Old 02-08-2007, 11:01 AM
Scrapper Scrapper is offline
AF Premium User
Exclamation Re: Oldsmobile problem
try starting it in neatrual......
Old 03-19-2007, 04:21 PM
maxj2291 maxj2291 is offline
All warning lamps are on in my olds 88 Speedometer going crazy and you turn the headlights on and it turns the fan on inside the car. please help
Old 03-20-2007, 01:25 PM
UncleBob UncleBob is offline
AF -Advisor
sounds like a battery problem, or battery connection
life begins at 10psi of boost
Three turbo'd motorcycles and counting.
