No low beam headlights
Recently the low beam lights on my 2004 S-10 Blazer quit functioning. I am assuming that it is the headlight dimmer switch.
My question is does anyone know where the dimmer switch is located and how to replace it? I have checked the Haynes manual I have and the dimmer switch is not covered in the manual.
Re: No low beam headlights
With the headlamp switch manually turned ON, operate the dimmer switch a couple of times, if the HI beams work, check both LO beam bulbs, they're probably burnt out. The dimmer switch is not a common problem.
You have to know how it works, to figure out why it doesn't. |
Thanks for the reply.
It turns out I was lead astray by some bad information (by the better half) that both went out at the exact same time. The both low beam bulbs were indeed blown.
