Go Back   Automotive Forums Car Chat > BMW > 5 Series
Old 09-29-2002, 08:16 PM
sinfestboy sinfestboy is offline
squeaking when i get in - 98 528i
when I get in my car, it squeaks whenever you move side to side, sounds like its coming from the the suspension..... what should I do about it?
ooh, cool smilie -:alien:
Old 10-16-2002, 07:03 AM
sledge sledge is offline
Are you sure the noise comes from your suspension? I bore a similar situation for weeks until one day I found out that the noise was coming from under my seat. I tilted the seat a bit and since then it has been quiet.
Old 10-25-2002, 02:37 AM
mc061579 mc061579 is offline
I had a similar complaint once. Does the problem only happen if the parking brake is on? I had to remove the rear left brake rotor. The tiny little shoes that sit inside the rotor for the parking brake were the problem. The backing plate wears and has that metal to metal contact giving a squeaking sound when you go to sit in the vehicle if the parking brake is on. I just used some white lithium grease on the backing plate and it took care of the problem. See if you notice your noise go away if the parking brake is not applied.
1999 528i Radio Stopped Working shibahill 5 Series 0 07-09-2010 03:51 PM
Squeak when turning PDModel98 Taurus | Taurus Wagon 13 01-04-2005 10:07 AM
Squeak when Turning Right!!! FrancoT Aurora 20 05-19-2004 08:45 AM
Squeaking when cold start from fuel cell area CODE4 Off-Topic 3 11-28-2003 01:06 PM
Squeak when driving and on brakes also deja08 Grand AM 8 10-10-2003 04:04 PM
