Go Back   Automotive Forums Car Chat > Ford > Expedition
Old 02-02-2007, 04:35 PM
carlosgonlez carlosgonlez is offline
4.6 code p401 egr valve problem
ok after cleaning egr ports changing pressure sensor replacing egr and egr solenoid and check engine light still on I was giving up but after looking on a post someone mention broken vaccum line went to my truck disconect the vaccum line from the solenoid and I found no vaccum on the line check it all the way and it was broken near the battery so I fix it and now problem went away.
I want to share this experience in this forum just make sure you check vaccum
on the line before doing something I spent $180 dollars changing good parts and the piece of line cost me 2.50 so is better to check that before buying or checking something else
Old 02-02-2007, 05:54 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Re: 4.6 code p401 egr valve problem
Thanks for the post. I hope it helps someone else that has the same problem.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
