Go Back   Automotive Forums Car Chat > Mercury > Cougar
Old 02-02-2007, 04:04 PM
lmeade lmeade is offline
'99 Cougar Speedometer
I have read the other threads & have found nothing that describes what I have encountered. My cougar is a '99, 2.5 V-6, with manual transmission. A few weeks back, once the car was warmed up(driving about 15-20 minutes) the speedometer would quit working. At this point the engine would run erratically..surging & slowing on it's own. The problem progressively got worse...check engine light came on giving a VSS code. I replaced the VSS but this did not solve the problem...still no Speedometer
Please help!
Old 02-04-2007, 01:32 PM
reekor reekor is offline
Re: '99 Cougar Speedometer
Check the VSS wiring and connection. If the new VSS is working and the wiring is fine, a scan tool will give you a speed reading when the car is moving.
Please help!
His, 96 Limited, 5.2 Magnum, Magnaflow CatBack System, HID Head & Fog Lamps, 242 T-case swapped , Rear Trac-Loc. Chrome grill added to match the wheels.
Hers, 96 Limited I6, 242 T-case, HID Head & Fog Lamps.
Old 04-15-2007, 10:45 PM
chipiwapa chipiwapa is offline
i had that same problem in my cougar but i have a automatic transmission i had 2 replace the speedometer sensor in the tranny after that it worked fine.
