2004 Blazer TCCM reset
Hi, New here. Having some 4WD problems.
Can the TCCM on a 2004 Blazer be reset by pulling the fuse or does it have to be done by disconnecting the battery? If I disconnect the battery,will it effect the theftlock on the radio? Thanks |
Re: 2004 Blazer TCCM reset
welcome to af.
to reset the vccm, disconect the negative battery cable for about 5-10 minutes. it should not affect the theft lock on the radio (i know it did not affect mine).
2000 Chevy Blazer ZR2 Performance Mods: Numerous Suspension Mods: Some, but not enough Exterior Mods: Just Right 1987 Buick Turbo T Dark Red Low 11 sec sleeper ![]() .030 4.1 block, PT6262E, & other odds and ends.... My Cardomain |
Thanks for your reply.
Sorry I put the thread in the wrong place. |
Yes it can if it is set ON so you better check - the owners manual tells you how. Fuses are "4wd" and "ATC" under hood and door that do the same thing as battery cable for the TCCM.
