Old 02-01-2007, 07:59 PM
tarheel44 tarheel44 is offline
4WD help on a 2000 z71
OK, the other day, I had my truck in 4wd and when I parked it, I put it back in 2wd. I went to leave a few hours later, and when I went to put it in 4wd, I noticed that the 2 hi indicator light was not lit up. The switch itself illuminated with the rest of the interior lighting, but there was no indicator light and the service 4wd msg came up. I tried to put it in 4wd, and I got nothing. No sound of anything engauging - nothing.
I read the threads on this forum and concluded that it was a bad switch so I changed out the switch - same thing - I plugged in the top harness, and the lights came on - no indicator light though. And when I plugged in the bottom harness, nothing happened.
I checked the fuse that was marked 4wd, and it was fine. I'm at a loss here.
Also, I took it to autozone and had them read the code, (since the stealership was gonna charge me $78 to do it, and they got nothing
I'll keep searching the forum, but any help/suggestions would be much appreciated.
Thanks
Old 02-06-2007, 01:43 PM
silverado122775's Avatar
silverado122775 silverado122775 is offline
Re: 4WD help on a 2000 z71
Sounds like the actuator to the xfer case may be out.
2000 Silverado Z71, 5.3L, K&N GenII Air Intake, Y-pipe Exhaust (no muffler), Bosch Platnium +4 plugs, 242k miles and still running.
