Old 09-29-2002, 02:36 PM
yellowdatsun yellowdatsun is offline
Pinging/knocking under load
I recently purchased an 88' Civic DX hatchback. It runs excelent, other than the fact that it pings/knocks under load. Such as when getting onto the freeway or going up hills. I have tried using "premium" gas and have even replaced the plugs, wires, cap and rotor. Retarding the timing all the way does help, but it is still there a bit. Obviously not good to run under full retard all the time, so there has to be a better solution. I appreciate any help. Thanks.
Ryan
Old 09-29-2002, 03:21 PM
MyFirst4G's Avatar
MyFirst4G MyFirst4G is offline
Send a message via AIM to MyFirst4G
you can buy this additive at pep boys or wherever and that helps a lot, on my 88 DX, i had the same problem.....
88 DX Hatch SOLD!
90 Si Hatch Wreck'd :
Done parting out.. Shell is going to fire dept soon to get roof chopped off for some kind of drill.. wait for the movie!!
96 Saturn SL2:
Daily Driver untill 91DX is running!
91 DX Hatch:
Its gonna be Painted CL Type S Grey w/ WW RS kit from 90 Si and JDM CRX front end conversion... Powered by a Turbo'd GSR Motor..... Loot is on the way!!
Official 4th Gen OG
Hype Race Crew
Old 09-30-2002, 08:37 AM
sastanley's Avatar
sastanley sastanley is offline
AF Premium User
Send a message via AIM to sastanley Send a message via Yahoo to sastanley
Welcome!
Premium gas has fixed that problem for me. The first thing I would recommend is to adjust the valves. That might help the pinging noises.
You need a feeler gauge and a screwdriver and a 12mm box-end wrench.
The Intake clearance is 0.007-0.009 inches.
The Exhaust clearance is 0.009-0.011 inches.
These are specs for an EDM SOHC 88 Civic, since that is the only manual I have electronically. The numbers for the DOHC are tighter than this (0.006 for intake and 0.007 for exhaust)
Just in case you didn't know (since you are a new Civic owner), the firing order is 1-3-4-2, so you can set the valves closed for each cylinder when you adjust them
heh heh - i know all this shiznit cuz we just finished getting the head put back together on my ZC this weekend - ZC = 85% complete!!
-Shawn
'91 Civic DX sedan
DOHC ZC, I,H,E, urethane bushings and mount inserts, rock chipped hood, some rust, stock steelies, nice comfy Integra seats, and the A/C works! What else could you want from an 18 year old car with 241,000 miles? Working on getting the Si tranny in now
Old 09-30-2002, 09:16 AM
darolh darolh is offline
Your only options are retarding the timing or higher octane gas.
Adjusting the valves won't do squat.
You might check you timing belt. If it's getting old it could be getting sloppy loose. When I changed my belt I tensioned it properly and it pinged a lot less.
94 sonoma knock under load perplexed783836 Problem Diagnosis 4 08-25-2009 05:59 PM
knocking and pinging under load. pies Silverado 10 11-18-2007 09:19 AM
00' Rodeo engine knock under load bishop242 Rodeo | Passport | MU 11 01-05-2006 12:46 PM
Does everyones valve knock under load? BigManLittleMetro Metro 4 11-08-2005 12:49 AM
