Go Back   Automotive Forums Car Chat > BMW > 3 Series
Old 02-01-2007, 11:48 AM
ralfnader ralfnader is offline
93 bmw 325i heat problem...need help!
The heater works fine when car is running but when you stop at signal, air will become cold till car start running again.
any idea what needs to be checked?? Car does not over heat and everything else is working normal........
Old 02-01-2007, 01:09 PM
Bear Bear is offline
Re: 93 bmw 325i heat problem...need help!
A couple of things come to mind, there is a heater valve up under the dash that could be faulty, but the first thing I would suspect is the thermostat. Thermosttat is a cheap fix and I would replace that first.
Old 02-01-2007, 01:26 PM
I'll replace the thermostat and will let you guys know if there is problem still.....Thanks
Old 02-01-2007, 01:28 PM
Old 02-04-2007, 07:50 PM
Question Re: 93 bmw 325i heat problem...need help!
i replaced the thermostat and lost the heat whatever I was getting while car is moving......there is no heat at all even when car is moving.........any idea??
Old 02-04-2007, 07:51 PM
Smile Re: 93 bmw 325i heat problem...need help!
i that heater volve on driver side or passenger side???
need guidance.....
Old 02-04-2007, 08:57 PM
Go to bimmerwerkz.com and check the post no heat on the E30 board.
Old 02-05-2007, 02:02 PM
is e36 is same as e30??? mine is E36.....
Old 02-05-2007, 03:17 PM
I see you posted at Bmmerwerkz on E36 board, I also posted on Roadfly with the issue. You may need to bleed the cooling system, and I am not sure if the E36 has the cooling bleed screw atop the thermostat housing, if so, you need to start her up and let her warm up and then crack open that bleed screw and let coolant flow (it is hot) a bit until no more bubbles appear in the coolant stream (may take a couple of tries). I will let you know what the buds at Roadfly think or you can go there and look, I post as Bubba at Roadfly.
Old 02-05-2007, 06:11 PM
You have one response over at roadfly on the E36 board.
