Go Back   Automotive Forums Car Chat > Buick > Rendezvous
Old 02-01-2007, 07:54 AM
41V 41V is offline
how to display SES codes?
is there a way to retreive SES codes?
light came on last week, stays on, car runs fine with no drop in performance.
Do I need an OBDII reader or is there some procedure to display the codes?
2002 CXL
Thanks in advance
BOB
BOB in Westfield, NJ
02 Buick Rendezvous CXL 80k orig owner
93 Trans Sport 240k white/gray orig owner
95 Cadillac SLS 116k
66 Corvette roadster 327 4spd nassau blue matching
Old 02-02-2007, 07:24 AM
Chameleon-kat's Avatar
Chameleon-kat Chameleon-kat is offline
Send a message via AIM to Chameleon-kat Send a message via Yahoo to Chameleon-kat
Re: how to display SES codes?
Some places like auto-zone will scan codes for free. For the SES light, the the most common cause is loose/misaligned/badly sealed gas cap. If the vous has a tether on the cap it could also get stuck underneath causing bad seal. I would check the cap first and if you find problem give it a few days with a few restarts to see if it goes away (the system runs a check every time it is re-started and needs a few 'good runs' of that before light will go out)
Old 02-02-2007, 08:21 AM
41V 41V is offline
yes, I went to autozone and they used their ODBII reader
got a code P0440
"The PCM has determined that a malfunction exists in the evaporative emission control system"
the guy there said it could be a number of things, ie catalytic converter, didn't have any more details
I was hoping there was a way to display the codes right on the dashboard, my 95 Cadillac ODBI can display codes by pressing "off+warmer" on climate controls, then can cycle through all the codes.
funnything, today the ses light was on for one minute, then turned off, first time it's off in a week.
Old 02-02-2007, 10:22 AM
evaporative emission control system is exactly what you would see for gas cap troubles, and because SES light went out after a minute today (back to the check that runs at startup time) it sounds like its happy now. Get gas in the last few days perhaps?
I don't think there is anything available for what you are asking about (code thing)
