Go Back   Automotive Forums Car Chat > Jeep > Wrangler
Old 02-01-2007, 06:52 AM
addicted2cars addicted2cars is offline
how do i replace a heater core in a 92 wrangler
antifreeze is leaking out on the passenger side floor and steam is coming out of my heater vents. i was wondering if anyone knows how hard it is to replace a heater core, iwas just gonna try to make it though winter then bypass the heater core for the summer but last night i could barely see to drive.
Old 02-05-2007, 08:14 AM
scoutinkeith's Avatar
scoutinkeith scoutinkeith is offline
Send a message via AIM to scoutinkeith
Re: how do i replace a heater core in a 92 wrangler
I had to replace the heater core on my 93 this past summer, it's really not that hard to do. mine didn't have AC though, so if yours dose, it may be a little different.
first, you'll want to drain the antifreeze, then disconnect the two hoses that attatch to the heater core on the engine side of the fire wall.
then, take off the 4 nuts (again on the engine side of the firewall) that hold the heater box to the fire wall.
once the 4 nuts are off, go inside, under thedash, and disconnect the electrical plug for the fan, and the cables for the flapper doors.
once everything is disconnected, pull the heater box(plenum), it may be a little tricky, you'll probably have to "rotate" it down as you pull it away from the firewall.
with the heater box out, you will see a metal plate on the back side(the side that was towards the firewall. remove all the screws from the metal plate, and remove it from the plastic part of the box. if I'm remembering correctly, the heater core is attatched to the metal plate with two screws/bolts, remove those, and swap heater cores, then reassemble everything.
once it's all back together, fill it back up with coolant. also, to make sure that you get all the air out of the system(it helps if it's parked with the front a little higher than the rear) , leave the radiator cap off, and start the engine, and let it get up to temperature. watch the leval of coolant in the radiator, and as it goes down, add more coolant untill the engine is up to temp(thermostat opens) and the coolant leval stops dropping.
give me a few minutes to find it, but I think I have a drawing that shows the location of the 4 nuts that you have to remove.
when all else fails, get a bigger hammer.
Vehicles:
2005 suburban 1500 4x4
all stock, ex-fire department truck.
1987 Grand Wagoneer
Old 02-05-2007, 08:23 AM
I couldn't find the exact picture that I was looking for, but here are a couple that might help.
http://www.autozone.com/servlet/UiBr...3d801fe9d5.jsp
http://www.autozone.com/servlet/UiBr...3d801fed40.jsp
Vehicles:
1987 Grand Wagoneer
