Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > F-Body Problem Diagnosis
F-Body Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 02-01-2007, 12:34 AM
stepho stepho is offline
Send a message via AIM to stepho Send a message via Yahoo to stepho
bi-polar idle
1993 Camaro z28 lt1 t56. Engine is out of a 94.
The car is acting weird when it is at idle, sometimes the rpms drop really low like around 500, sometimes it stalls out but normally doesn't. Recently its started staying in the 2000rpm range at idle, at certain times. As far as I can tell there is no rhyme or reason to when it idles at 500 or 2000 rpms, normally it stays around 1000.
Originally Posted by sportlinetta
lol, u guys are dummmmmmmmmmmmb im 14 n i know more. i gotta 88 camaro.
would that mean get a new cylinder or plug???
Old 02-01-2007, 08:49 AM
CamaroRS92 CamaroRS92 is offline
Re: bi-polar idle
From past experience of a similar nature of irradic idle speed,
My suggestion is to "Thoroughly" check for vacuum leaks first.
This could save you a lot of hassels , time and money in the long run.
Vacuum leaks - even small ones - can cause some strange behavior of idle speed control
Old 02-01-2007, 10:36 AM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
Re: bi-polar idle
Has it been doing this since the heart transplant?
Old 02-01-2007, 06:17 PM
Re: bi-polar idle
Yes. It didn't run before the swap, so I'm not sure if it was doing it before though.
Old 02-02-2007, 09:47 AM
Blue Bowtie's Avatar
Registered Offender
Re: bi-polar idle
Is the IAC clean?
Old 02-02-2007, 03:05 PM
ikeyballz ikeyballz is offline
Send a message via AIM to ikeyballz
Re: bi-polar idle
hey, sometimes its also the MAF. mine started doing that too, if you havea diff maf, try that one.
Car:
1997 M6 SS Camaro [ white ]
285's in the back
all else = STOCK.
