i've got a 90 model towncar with a 5.0 engine and this past saturday the car would not crank. i checked the fuses under the hood and i found that the fuel pump fuel was blown. replaced the fuse(same amperage) got in to turn the switch and the same fuse blew again. Can anyone help me out????????
Re: Fuel pump fuse anyone??????
Sean |
Hello,
The TC does have a fuel pump relay. It is usually located under the hood. I could point it right out to you under the hood of an '89, but the 90 is different. These can go bad--and yes maybe it would blow a fuse as well. It certainly would be worth checking that before assuming the pump is bad. If you get no other help here, try Lincolnsonline site also. Usually a pump will just quit without blowing a fuse--seems unlikely that it would be that. |
