can anybody tell me which wire from the harness going into the instrument panel is for the speedometer?
Re: 2002 jimmy speedo power wire
PCM/VCM VSS out is pin C2 DK/green wire
shut off speedo
does anyone know which wire in the harness i need to splice into to add a toggle swich to my speedometer so i can turn it on and off? thanks in advance!!!
That's not advisable. Interrupting the signal will cause transmission shift problems (loss of 1st, 2nd, and OD), and disable the ABS.
Keeps people from trying to get around the speed limiter, and disabling the mileage odometer..... |
thank you
But as said it is not advisable. Can led to complications and may be illegal under speedometer fraud laws. With the newer computer system the mileage info may be stored in the pcm and body pcm to. Do so at your own risk.
i just finnished and it is the dark green wire going into instrument cluster. take cluster out of dash, disconnect wiring harness, splice wire and connect to toggle switch. now you only put on mileage when you turn switch on. drove for about 2 hours with no side efects at all.
