Old 01-31-2007, 02:14 PM
justin476 justin476 is offline
rear defog not working
rear defog doesn't work in my 98 z42. The amber light turns on when i push the defog button and everything, but it's not doing it's job. Any suggestions?
Old 01-31-2007, 03:03 PM
z24forlife's Avatar
z24forlife z24forlife is offline
Re: rear defog not working
Hi on your rear window from the inside you'v got 2 pins welded onto the defoger on either side as to left and right sides.. Just check to see if they'v unwelded from the window. If so then you'll need to get them welded back onto the rear window.. good luck
z24forlife
Old 02-01-2007, 11:35 PM
no they're still on pretty good. Any other suggestions????
Old 02-02-2007, 10:02 AM
z24forlife's Avatar
was it ever working before.... have you got tints..????
z24forlife
Old 02-02-2007, 08:36 PM
just got the car two weeks ago, and no it doesn't have any tint. Checked the fuse and connectors. All seem fine. Wiring issue i'm guessing?
Old 02-07-2007, 09:59 AM
Ryan066 Ryan066 is offline
check for power to the rear window with an ohmmeter
then check with a test light and tell us what happened when doing both tests
