Old 01-31-2007, 01:48 PM
CJCGT CJCGT is offline
Speedometer going crazy
I am having a problem with my speedometer working sometimes and then other times it so far off from the speed i am going and all it does is shake from side to side and you can hear is rattling like the cable is loose or something. Any ideas of what i should do is it something i can fix myself or do i need to buy a new cable and take it to a shop?
Old 01-31-2007, 01:55 PM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
Re: Speedometer going crazy
the cable runs from the back of the speedometer to differential in the transmission. you can check the connection of the speedo gear from the top of the transmission. you'll need to remove the battery, battery tray+washer bottle intake pipe and air filter. then you will see the cable running into the back corner of the transmission. there is one 10mm bolt that hold the gear in. remove that, and you can pry, gently, the gear out of the transmission.
for more info, go here.
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
