Go Back   Automotive Forums Car Chat > Honda > Interior | Audio | Security
Interior | Audio | Security Tech forum to assist in Honda/Acura Interior, Audio and Security.
Old 01-31-2007, 10:36 AM
yuraRS yuraRS is offline
how to make interiour noise quiter
hey guys, i just wonder if its possible to make interiour noise more quite cuz im driving an integra and also have loud muffler, so its too noisy to drive on highway so i was thinking maybe there is a way. what i was thinking maybe put some wool under plastic covers and on doors, under panels rip stock plastic cover and install some thicker one. theoretecly it should block sound from outside but before ill sdtart doing it maybe someone have some advise for me thank you. oh yeah and sorry if i misspelled something english my second language and i think you can see that lol
Old 01-31-2007, 12:53 PM
Galuple Galuple is offline
Re: how to make interiour noise quiter
Dynamat ;-)
Old 01-31-2007, 03:14 PM
whats that? lol can i get it at home depot?
Old 01-31-2007, 04:10 PM
CivicSpoon's Avatar
CivicSpoon CivicSpoon is offline
There is no Spoon
http://www.dynamat.com/ It's an insulation material that helps to keep out noise as well as keep sound in (better sound from your stereo). I don't know about Home Depot, but you can get it at Pep Boys, Best Buy, AutoZone and pretty much any car audio shop.
There are quite a few companies that make similar products, so shop around for the best deal.
http://www.designengineering.com/pro...sp?m=sc&cid=13
http://www.edesignaudio.com/edv2/index.php?cPath=24 (a special paint, look around the site and you'll see their type of foam too)
And here's a nifty little chart to give you some ideas of where to put it (not just the eDead stuff, but all those products):
http://www.edesignaudio.com/edv2/ele...edeadwhere.php
Old 02-01-2007, 10:26 AM
wow i didnt even know there is such a product on the market, awesome thank you alot! just one more question - i found eDead liquid and mats, does anybody know what works better? or there is not really a difference in quality its just different applications?
Old 02-01-2007, 10:59 PM
808hardbody's Avatar
808hardbody 808hardbody is offline
stock muffler?
________12.5....5psi. nuff sedd ___________
Old 02-02-2007, 02:17 AM
CivicSpoon's Avatar
There is no Spoon
I'm sure if you search around on here and the net you'll be able to find a review of each.
Old 02-02-2007, 10:12 AM
nope its some loud aftermarket sounds so good but anoying after driving for a long time
Old 02-02-2007, 01:45 PM
ok i did a little reseach and chose this option: buy some mats, for the whole car from roof to flor and than cover it with couple layers of edead liquid thing (v3 i think) and than all empty spots fill with foam even in plastic trim pieces, especially in the trunk area.
but im a new at this and dont know anything so any advises? and did anyone painted ove mats before?
Old 02-02-2007, 02:09 PM
CivicSpoon's Avatar
There is no Spoon
I would put the paint on first, see how the sound is, and then put the mats over the paint if you stilll need more sound proofing. Then have a friend rev the engine while you're in the back of the car. That way you could probably save on mat (and weight) by being able to pinpoint where you need it the most. And you will be adding quite a bit of weight with all this stuff. A lot of people remove the stock sound deadening tar to save weight, less weight = faster to an extent. And in a '92-'95 Civic (just to give you an idea), there is about 20lbs worth of tar on the interior firewall and floor. So adding all that extra stuff will just add on to the weight of the tar that's already there in stock form. Just some things to think about.
Old 02-02-2007, 03:07 PM
yeah thats a good advise, but will mats stick good to that paint?
and do you think i wold be good with two gallons of paint
Old 02-02-2007, 04:01 PM
CivicSpoon's Avatar
There is no Spoon
I really have no idea. On that one link that says where to put the stuff, it says to use 1 gallon or 50 sq ft of the mat. So I assume 1 gallon will cover 50 sq ft, then just figure out how many sq ft you have inside the car. And from that I would guess that between 2 and 3 gallons would cover the car, probably closer to 3 (but who knows what they consider the average car size to be).
