Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 01-30-2007, 10:45 PM
eclipsed at 3am eclipsed at 3am is offline
Send a message via MSN to eclipsed at 3am
tps check engine light
if a throttle position sensor is not adjusted correctly, would it throw a code? i was thinking about it today, and my answer would be no, because it measures how much the throttle plate is open. so if its adjusted improperly, the ecu just thinks your foot is on the gas all the time. plus if it was adjusted improperly, it would always be running funny. am i right?
i was thinking, if the sensor itself was bad, such as corroded or a short or some type of problem, it could be a problem that throws a code, and the code stays, but the problem would be intermittent.
im about to spend $150 on a brand new throttle position sensor at advanced auto. i did just get a new throttle body with a new IAC and tps on it, well, rebuild anyways. i cleared the code, and it came right back, and its the tps malfunction. does it sound like the tps is bad?
i noticed that a few days ago, when the weather was warmer, the car ran great. but last night and today, its been running crappy. i dunno if that affects anything. i did however go through all the intake piping, fmic, etc, and looked for any leaks and loosend and then tightened all clamps, and put rtv on the j-pipe and the throttle body gaskets. if there are any leaks, it would have to be a hole somewhere that i didnt see, of the intake manifold. if the throttle position sensor IS working correctly, and the ecu throws a code for the TPS, what else could be the problem? also, the throttle percentage on the AFC reads 1,2,or 3 percent sometimes, even if the idle is lower or higher or bouncing around. im starting to suspect a loose wire. before i buy the sensor, im going to check all these little things. i just wanted to know if anybody can think of anything?
ohhh one more thing. when the car is idling nicely, it shifts better. when it idles nice, it slides into 1st gear, sometimes i might have to tap the gas a little, but it goes in with no grinding. when it idles like crap, it grinds all the time and locks in gear sometimes. dunno if that helps or not.
thank you guys for any info you may have?
eclipsed @ 3am
http://www.cardomain.com/ride/2505283
Old 01-30-2007, 11:29 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Re: tps check engine light
I would check around online or some other places for a known good TPS before you go and spend $150 on one. I'm sure someone around here has an extra laying around or ebay would be the next best bet.
95 Talon TSI AWD
97 Eclipse GST
Old 02-02-2007, 08:00 PM
defiancy's Avatar
defiancy defiancy is offline
Stay classy San Diego
My car threw a TPS code. My 91, and that bastard wouldn't start for shit.
Threw in a new ecu and it cranked right up. True story.
(Edited for my horrible use of the word through instead of threw)
1991 GSX 2.3 Stroker
