Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 01-30-2007, 09:20 PM
Mr. Rivera Mr. Rivera is offline
Talking '91 caprice classic tranny
My car has a LO3(305), but not to sure about the tranny, I was told 700R4, 4L60,and 4L60E! Which one is it,cause its burned up and would like to rebuilt it to save sum money.
Old 01-31-2007, 12:18 AM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: '91 caprice classic tranny
Welcome to AF!
The transmission WON'T be a 4L60E - that's an electronic controlled transmission that first saw use in the Caprice in 1994 ('93 in other carlines).
The 700R4 and 4L60 are for all intents and purposes, the same unit, although I refer to a particular trans as a 4L60 if it has an auxiliary valve body and a 700R4 if it does not. All made between 1987 and 1993 fit into this category (4L60) while 1986 and earlier are pure 700R4s.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 02-01-2007, 04:44 PM
You cant go wrong w/ a Dealership right? I gave them my last eight they told me 700R4 is what camn in it(everything is still OEM). A local transmission shop here in my home town looked @ it and told me 4L60. Is the dealership wrong?
Old 02-01-2007, 05:15 PM
corning_d3 corning_d3 is offline
Send a message via Yahoo to corning_d3
My '91 has a factory 700R4. 4L60's came later.
2007 Certified DaimlerChrysler Service Technician...
True blue GM at heart.
Old 02-01-2007, 07:20 PM
silicon212's Avatar
Confoundingly Lucid
A "4L60" is a redesignation of the TH700R4. It is said to be easier to determine what it is to be used in with the 'new' designations. The way this works out is:
First digit is number of forward speeds
Second digit is design - L for Longitudinal mount (front engine rear drive) and T is for Transverse mount (front engine front drive or mid engine rear drive [Fiero]).
Third and fourth digits are the weight capacity (60 is 6,000 lbs GVW etc).
So, in 1987 (yes this happened in 1987 - look it up), GM redesignated their transmissions. The transmissions that didn't get a redesignation are the TH200C and 4R models.
TH400 became 3L80. TH700R4 became 4L60. TH125C became 3T40.
Much of the paperwork on the cars continued to call the TH700R4/4L60 a TH700R4 into the 90s, but the fact is the official redesignation took place for the 1987 model year.
TH700R4 and 4L60 are interchangeable terms beginning with the 1987 model year.
