Old 01-30-2007, 08:45 PM
d1nonlyjv43's Avatar
d1nonlyjv43 d1nonlyjv43 is offline
Brakes
1996 2.2 automatic, Brakes were locking up befor taking to be inspected /Car got inspection and it needed the brakes to be adjusted because it was locking up. The rear brakes that is which is drum brackes. Well after that for about 2 or 3 weeks it was okay then it went back to the same thing. The rear brakes will lock up and make the car skid in the back when coming to a stop and when you let up of the brake u can here da brakes in the rear drag a little. What could cause this.( A bad wheel cylinder,rear shocks gone, what could cause it please help.)
Old 01-31-2007, 11:19 PM
Re: Brakes
Somebody please give me some answers to this problem thanks
Old 02-01-2007, 12:52 AM
Jmrec100's Avatar
Jmrec100 Jmrec100 is offline
Re: Brakes
Check your drums. I had a problem with my rear brakes a while ago. I replaced the shoes, adjusted them, But they were dragging. When I hit the brakes, I heard a clunking sound. After numerous trys and I changed the shoes again, I found the drum itself was out of round. May not be your problem but something to check.
Old 02-07-2007, 10:09 AM
Ryan066 Ryan066 is offline
Re: Brakes
i dunno if this is normal but i see it on a Bunch of cavaliers... seems to be when moisture builds up in the drums,, like a cold day then u bring it in a hot shop and take it out and it will do it.. ive see it with cavaliers that have un adjusted brakes and adjusted up good brakes. it will go away once they are heated up tho
Old 02-07-2007, 11:11 AM
alan &marge pepper alan &marge pepper is offline
Re: Brakes
this dose not just happen to cavaliers!
what happens is the drum wears and brake shoe dust lays in the drum and when the dust gets damp it causes the shoe to lock up the wheel aggressively. until it drys out.
you have to set the brakes up to stop this. what happen is when the drum wears a lip forum on the outter part of the drum and the dust can not get out.
what i do is grind this lip off and i have no more problem until it builds up again in a year or less.
ps your self adjusters are not working to keep your brake shoes set up..
Old 02-08-2007, 11:16 PM
pyro4329 pyro4329 is offline
Re: Brakes
I think that says it right there. opcorn:
College
Old 02-09-2007, 11:33 AM
muff34 muff34 is offline
Re: Brakes
depending on how far you want to go with this I`d get some brake cleaner and spray the entire area to get rid of previously mentioned dust. Or you colud strip everything down and clean everything and lube brake shoe contact points . also take adjusters apart ,clean and lube them. also do the drum lip removal as previously mentioned. Also one other thing if one of the wheel cylinders has previously leaked and has contaminated the brakes shoes ,the shoes shoes should be replaced as this can cause the lock up problem as well.
Life Is A Highway ,Enjoy The Ride
