Old 09-29-2002, 12:56 AM
iVteC_bOi iVteC_bOi is offline
Send a message via AIM to iVteC_bOi
thin or fat wires for car stereo??
wat is the best wire for car stereo....casue in my car i use the thin wire...is that good or bad?? will i kind of want to get the big thick wire casue i heard that it save yur battery..and stuff like that...so yea i would to know wat is a good wire to use in my car
Old 09-29-2002, 10:47 AM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
it's kind of hard to follow your post .... are you talking about power wire for the amp, speaker wire or what ?
Old 09-29-2002, 02:28 PM
speakers
am talking about the whole systeme like the amp and the speaker
Old 09-29-2002, 07:53 PM
Sacker90 Sacker90 is offline
Send a message via AIM to Sacker90
Well for better sounds quality and to make sure your wires dont burn up you should use thicker wires. Your subwoofers will sound alot better with thicker wires cause more power can get through easier and faster.
Old 10-04-2002, 03:27 PM
turbcivic's Avatar
turbcivic turbcivic is offline
I run 4 gauge to my cap, block and amp and then run 8 gauge to my speakers.
Old 10-12-2002, 04:01 PM
GSteg's Avatar
GSteg GSteg is offline
Send a message via AIM to GSteg
size doesn't not affect sound quality
I love them sub wufers
Old 10-12-2002, 05:25 PM
strodda strodda is offline
im getting a 800w(rms)amp and a pair of volf 12's(500w rms). right now i have 4gauge to a block splitting it to two 8g. 12v wires. would that still be thick enough wires for my new amp? and what size speaker wires should i use?
Old 10-12-2002, 06:42 PM
kicker1_solo's Avatar
kicker1_solo kicker1_solo is offline
Send a message via AIM to kicker1_solo Send a message via Yahoo to kicker1_solo
that should be fine for your amp, and any size speaker wire is fine, the stock speaker wire that comes in your car originally is good enough for speakers as it doesn't affect sound quality like GSteg said.
2000 BMW 323IT
1954 Ford F100
With every post my penis grows smaller
Yakima Valley Truck Club Yakima Washington
Old 10-12-2002, 07:32 PM
what about the wires going from the amp to the subs? i assume i'd need something thicker than those tiny stock wires.
Old 10-13-2002, 12:04 AM
won't make a noticable difference, will be a more direct current, but you won't be able to tell a difference.
2000 BMW 323IT
1954 Ford F100
Old 10-13-2002, 12:33 AM
well, thanks again kicker. dont you just have all the answers
i got one more for ya since were on the subject of supplying power. since im gonna be pushing a higher wattage now, is a cap necessary? or would it just stop my headlights from dimming during the night?
Old 10-13-2002, 12:46 AM
how many watts are you going to be running all together? If you're going to be running anything over let's say 500 watts, then you should get at least a .5 farad cap, let's say over a 1000, then at least a 1 farad cap. It does more than just fixes the light dimming problem. Caps aren't that much, you could get one off e-bay for like $40-50 that will solve all your problems.
2000 BMW 323IT
1954 Ford F100
Old 10-13-2002, 12:53 AM
it would be 950w rms. guess i should get one then. ive been lookin on ebay and i found a couple like you mentioned. do those cheaper ones like http://cgi.ebay.com/ws/eBayISAPI.dll...tem=1387422888 work just as well?
Old 10-13-2002, 01:07 AM
yep, and Legacy is actually a pretty decent brand. You could probably get one even cheaper than that if you got one that didn't have the digital read out on it. That one's digital, which means it has a little electronic screen that gives you a read out, that's cool. But if you're on a tight budget, the non-digital ones do that same thing and are a bit cheaper.
2000 BMW 323IT
1954 Ford F100
Old 10-13-2002, 10:51 AM
Audio Guy
even worse, the digital readout makes the caps ESR so high that it becomes useless for the purpose at hand.
