Old 01-30-2007, 05:29 PM
rtmwolf rtmwolf is offline
no start fuel and fire
i am working on a 98 gmc safari 4.3l and have fuel and fire but the injectors dont seem to be working there are no codesfound mouse nest near the dist. it cranks fine ut can tell no fuel. just replaced fuel pump because of not working fuel pressure is 60 when first crank but does not hold pressure long would love
Old 02-10-2007, 06:02 PM
Blue Bowtie's Avatar
Registered Offender
Re: no start fuel and fire
Did the mouse get you partway through the posting? Was there something else?
I'd look closely at the wiring near the distributor.
Old 02-13-2007, 11:11 AM
i checked all the wiring near the dist. and found all ok did a continuity check on same with the same results. had another mech. look at it and he thinks it is the comp. but i dont think so. sending it off today. I hope this works but if you have any other ideas i would welcome them thanks
Old 02-13-2007, 02:37 PM
Registered Offender
Since it cranks fine, it's not likely a PassLock issue. Make sure the injector pod has power (injector fuses), and the crank position sensor is switching the signal line to the PCM. Even a "dead" cam position sensor will evenetually cause the ignition and SFI to fail to operate. The fact that you have "fire" (ignition?) would indicate that the CKP and CMP are at least reporting to the PCM, but it wouldn't hurt to verify that.
Old 02-14-2007, 11:42 AM
thanks for all your help i really apreciate it its hard to find good mechanics to talk to here in mexico
