Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 01-30-2007, 05:10 PM
Repteel Repteel is offline
Unhappy rough idle
my friend has a 93 civ hb, d15b7 motor, idles at 1800 rpm for 30 seconds, the drops down to 450 and then yoyos back and forth. after driving the car for about a minute the engine light comes on and sets code 43, car is buring super rich, we removed the IAC valve and cleaned it with brake clean, the IAC doesn't make any noise when you shake it, cleaned the throttle body, swapped the TP sensor and the HO2 sensor from a good working engine, anybody got any ideas????
Old 01-30-2007, 06:59 PM
AudioGuy93DelSol's Avatar
AudioGuy93DelSol AudioGuy93DelSol is offline
NA is Best!
Send a message via AIM to AudioGuy93DelSol
Re: rough idle
Try running some fuel system cleaner through it. See if that clears it up.
Oil leak? What oil leak? That puddle under the car is just sweat from all that horsepower.
"How many NASCAR passes is that worth? 500?" (Schumacher passing Raikkonen)
Emily is amazing, and she messed with my sig AGAIN!
Old 01-30-2007, 07:47 PM
Re: rough idle
already put combustion chamber/ injector cleaner with last gas of tank, would the fast idle screw make it yoyo up and down??
Old 01-30-2007, 08:26 PM
NA is Best!
Re: rough idle
Yeah. Check this out.
Old 02-01-2007, 09:07 AM
jclark jclark is offline
Re: rough idle
A vacuum leak will do the same thing.
Check all your hoses and intake connections very carefully.
Jim C.
Old 02-01-2007, 11:50 AM
Schister66's Avatar
Schister66 Schister66 is offline
AF -Advisor
Send a message via AIM to Schister66 Send a message via MSN to Schister66
Re: rough idle
x 2
2015 DGM STi - 2006 SGM STi - 1999 Built/boosted GSR
Old 02-01-2007, 08:02 PM
Re: rough idle
well your both right, the FITV housing is cracked, so it's causing a vaccum leak, we've put silicone on the crack as a temp fix, seems to be working ok, now we're looking for another housing or FITV, thanx for all the help
