Old 01-30-2007, 10:26 AM
handsomdevil00 handsomdevil00 is offline
Exclamation HELP!!! 1988 Honda Accord PROBLEMS!!
I have a 1988 Honda Accord LXI 2.0L Fuel Injected Manual Transmission. The car has almost 192000 miles. Car has been sitting for about 18 months. I want my honda back. I have replaced fuel injectors, fuel filter, oil filter, oil synthetic, air filter, ignition igniter, ignition coil, distributer cap, distributer rotor, ngk spark plugs, ngk spark plug wires, and a used idle air control valve. i have cleaned out the throttle body. but the car still has a suging idle. when i start the car(warm or cold) it idles at just above 2000rpms. slowly goes down and between 10000 and 2000rpms surges. like im reving the car. once the car gets to normal operating tempatures. the cooling fan comes on twice. the car idle fine...about 750 rpms. i am also having a problem when i drive the car losses engine power. i can accelerate from 0 to 55 fine. its not the 0-55 that is the problem it holding what ever speed. i try to maintain a speed and the rpms drop like a rock. i push on the pedal and get no response. what could be causeing this?
Old 01-30-2007, 11:40 AM
Re: HELP!!! 1988 Honda Accord PROBLEMS!!
I just replaced my fuel pump. the car is all screwed up now. i started the car and 4000rmps is what i say. then 4 seconds later it starts to idle up and down between 4000 and 1000. oh my god what is going on. do i need a new ecu. i looked before i replaced the pump and no lights come on. should i get a new one?
Old 01-30-2007, 11:48 AM
does anyone know a way to get a computer tested?
Old 02-01-2007, 11:34 AM
cdc692003 cdc692003 is offline
After your can sat for so long ....you did drain all the old gas out of the tank
right? fuel sounds like the problem .....
Old 02-01-2007, 12:33 PM
I did not. it had close to 2 gallons left in the tank. i put 2 gallons of premium grade in as well.
Old 02-01-2007, 03:28 PM
somick's Avatar
somick somick is offline
It looks like you replaced all parts that may give you troubles. The only one questinable might be used IAC valve. Was it known good?
Another questionable part might be your computer but I have no idea how to test it. Probably get a known good one.
Good luck!!!
Sam
Originally Posted by RIP
Please post back when you fix it so we all will learn something
