Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 01-29-2007, 11:06 PM
smoke121212's Avatar
smoke121212 smoke121212 is offline
Exclamation need help
i need to know what would be a good engine swap for a 1996 mitsubishi eclipse GS.
I wanna get into the race scene but cant get any info on the web about this
Old 01-29-2007, 11:16 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Re: need help
A good swap would be the same motor that came out of it, because it's the only one that will really fit. If you wanna get into the race scene, become a regular here and read all you can. Also give www.2gnt.com a look, they have an assortment of GREAT info in the tech section. My suggestion is find a used 420a motor, tear it apart, clean it up, and then build the shit out of it. Then you'll need a nice turbo and good fuel setup. That should get you some decent power.
95 Talon TSI AWD
97 Eclipse GST
Old 01-29-2007, 11:22 PM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
Re: need help
I suggest you get a different car if you are serious about "getting into the race scene". You will end up dumping more money trying to make that thing fast than if you started off with a car less expensive to modify, like a GST/TSI/GSX.
You really need to know what your doing when you plan to go big with the 420a motor. I suppose you could just read on this site as much as possible and if you think your up to the challenge then go for it, but it won't be cheap to build it right.
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 01-29-2007, 11:31 PM
Re: need help
yeh but isnt my stock motor basically a chrysler 420A motor
Old 01-29-2007, 11:47 PM
Re: need help
That's exaclty what it is, but nothing else will fit into that car to make it worthwhile. Your best bet is to either A) Sell it and get a stock turbocharged car like _eclipse_ said, or B) Build up the stock motor and turbo it. Either way, a turbo is the only way you'll get any power out of that motor.
95 Talon TSI AWD
97 Eclipse GST
Old 01-29-2007, 11:59 PM
Re: need help
Exactly my point. It takes a lot of money to get that thing making more power than a stock turbo DSM. Even if you buy a turbo kit, you will likely need some professional to install it seeing as you have very little experience under the hood. So it will cost you anywhere from $1,500-3,000 and that only gets to to the stock power level of a 4g63t. Your in for a long road if you stick with that car, that's the only engine you get there is no easy swap.
'92 3000gt SL
Zoom Stage 1 Clutch
Old 01-30-2007, 10:10 AM
Re: need help
ok thanks a lot for the help guys
