Go Back   Automotive Forums Car Chat > Ford > Expedition
Old 01-29-2007, 10:05 PM
alonewolf85 alonewolf85 is offline
2000 epedition wont start
the motor spins over - no sign of life ? any ideas - its been sittin a few monthes - sprayed starting fluid and got nothing- pos security?
Old 01-29-2007, 11:55 PM
808hardbody's Avatar
808hardbody 808hardbody is offline
Re: 2000 epedition wont start
did you check your fuel pump relay? Located under the passenger side glove box. There is a reset button. Hope this helps
________12.5....5psi. nuff sedd ___________
Old 01-15-2013, 06:18 PM
72mino 72mino is offline
Sorry about reviving a 6 year old thread, but what was the problem with your Expedition. I'm looking at a navigator that's been sitting for almost 2 years (parked due to suspension problems) and now it turns over strong, but won't start.
Old 01-16-2013, 07:50 AM
65comet's Avatar
65comet 65comet is offline
What year Navigator? I suggest climbing under and having someone click the key to the on position (not trying to turn over) and listen for the fuel pump to engage and charge the system as a first step.
Two years is kinda iffy for the fuel to still be good, but I've had cars sit longer that still started. Might need to empty the tank and get a new fuel filter as a starting point. The reason I ask for year is that there is a problem with the fuel control module rotting out 04' - 07'. It is aluminum and mounted on a steel rear frame section. The two differing metals cause the aluminum to erode away exposing the electronics inside.
Old 01-16-2013, 02:50 PM
Thanks for the reply. It is a 99, 32 valve. When I am able to look at it I will take my fuel pressure tester.
