Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 01-29-2007, 07:11 PM
Roslyn Roslyn is offline
HELP! 98 bonneville ext temp flashing-no heat
Recently the check engine light came on and was flashing. We started by replacing the plugs and found bad plug wires. This solved the problem for the check engine light. It took about 7 starts to turnt the light back off. We had disconnected the battery also. Now the ext temp is flashing and the heater is not putting out even warm air. It worked fine before the plugs, wire and battery. Does anyone have ideas of what I should try or check first? I live at least 100 miles from the nearest shop and would like to try some options before I take it in.
Thanks!
P.S. it was only 7 degrees this morning and I get home way after dark too.
Old 01-30-2007, 03:54 PM
ChemMan ChemMan is offline
Re: HELP! 98 bonneville ext temp flashing-no heat
Check your coolant levels. Hope that helps.
2010 Mazda CX-7 2.5L 12000 miles
2003 Chevy S10 Extreme 4.3L 57000 miles
1995 Buick Lesabre Custom 86000 miles RIP
2002 Pontiac Sunfire SE 130000 miles RIP
1997 Pontiac Bonneville SE 91106 miles Totaled by attempt to steal the car!!
R.I.P. 1978 Ford Fairmont 83000 miles
