Go Back   Automotive Forums Car Chat > Geo > Tracker
Old 01-29-2007, 06:42 PM
igya igya is offline
Really need help with front crank seal!!!
I'm pretty sure the front crank seal is shot on my '96 Tracker with a 1.6L, 16 valve, 4 X 4, but I'd appreciate a little info. Is that seal mounted in the oil pump housing? And, is there any way to keep from having to drop the front differential? How 'bout it guys, got any news for me? Thanks up front!
Old 01-30-2007, 11:45 AM
HAWG HAWG is offline
Re: Really need help with front crank seal!!!
yes the seal is located in the oil pump housing. As for dropping the front diff, I'd have to check the procedure in the service manual.
Old 01-30-2007, 02:16 PM
edmcm2000 edmcm2000 is offline
Go here and you'll find everything in detail that you need to know. (You don't mess with the diff)
http://www.suzuki-forums.com/suzuki-...a-geo-tracker/
Old 01-30-2007, 02:37 PM
Wouldn't it be possible to just gouge out the old crank seal and insert a new one by removing the crank sprcket and belt guide?
Old 01-30-2007, 05:30 PM
That's exactly how it's done, see the link on my last post where you can search out all the details and potential problems that you could run in to. Edmcm
Old 01-30-2007, 05:55 PM
Hey, I really appreciate your info. I searched that link, but I couldn't find a post on that procedure. I would think that the only screw-up would be if the bearing, or engine bearing surface is damaged. Thanks again man!!
