Old 01-29-2007, 06:15 PM
micali micali is offline
Instrument cluster problems, anyone else?
My car is a 01 3.0 FFE and the gas guage flux's and never ever reads correct. It also beeps when ever it wants like I haven't put my seatbelt on. It will beep beep beep and repeat this three or four times.
For a while the bat light would come on but nothing would be wrong. I've replaced the instument cluster and that didn't change a thing but the mileage.
I am tired of going off the mileage to know when to fill up. I've ran out of gas way to many times and I am tired of it.
Anyone else have this problem.
Old 02-18-2007, 07:32 PM
Re: Instrument cluster problems, anyone else?
anyone else have this problem?
Old 02-18-2007, 11:10 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
The beeping may be indicating to you that the Supplemental Restraint System (SRS) light is out. When you turn the key to the run position, does the Airbag/SRS light illuminate during the bulb test? If not, the beeping is to indicate that the bulb is out. What is the beeping pattern (ie: beep, beep, beep, pause, beep, beep would indicate a code 32)?
Some of the FFV Taruii had a distance to empty module, that may be faulty on yours. Do you get a "low fuel" indicator when you have about 50 miles worth of fuel remaining? Maybe I should ask if you used to get a low fuel indicator.
-Rod
Old 02-19-2007, 06:47 AM
Millermagic Millermagic is offline
The gas gauge in these is not accurate at all. I just fill up around 200 miles.
- Leather - Transmission Cooler - Gen III Tweeter Sails - Gen III Rocker Covers -
As you walk through the valley of RICE, you shall fear NO V-TEC, for torque is with thee!
Old 02-19-2007, 06:19 PM
pchop pchop is offline
i seen something about water getting into the GEM MODULE , i will see if i can find a article on it. this would certainly cause these types of problems.
Old 02-26-2007, 09:58 PM
your right the sRS light bulb is out. Thanks for the idea. My guage will read anything at anytime. It is never correct and if it looks to be correct it will change while I am driving.
The beep is 5 beeps followed by 5 beeps.
